Loading...
Pages: [1]   Go Down
Author Topic: *SOLVED* How to reverse a 5 volt motor  (Read 1361 times)
Offline Offline
Newbie
View Profile
Hi. I am somewhat confused around this.
I have a 5 volt motor. DC.
I need to reverse the motor when it detect a HIGH signal,
and run it normal (forward) when it detects a LOW signal.
How would I do this on my Arduino Uno? smiley-roll-sweat
Do I need a stepper motor shield? smiley-confuse
« Last Edit: September 19, 2011, 07:32:08 pm by Haunted360 » Logged
New Jersey
Offline Offline
Edison Member
View Profile
Not a stepper motor driver, but a motor driver of some sort - search the forum for H-bridge
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Look at a part like this
http://www.ti.com/lit/ds/symlink/l293d.pdf
It uses transistors to basically switch the motor leads from +supply/gnd for current flow in one direction, to gnd/+supply for current flow the other direction to make the motor spin the other direction.
Depending on how big your motor is, what voltage/current is required, you may be able to use this part, or find a beefier part, or use discrete transistors with a chip like this to drive/control the transistors.  You may be able to use an existing motor shield for this.
What will the source for your HIGH/LOW signal? Reading that from a digital pin is usually the easist part of the project, such as from a mechanical switch.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Thanks!
The HIGH and LOW are sensors for the where abouts of a disc. It is for a CD-ROM drive.
Here is the somewhat basic logic:
If sensor 1 detects disc, forward motor.
if sensor 2 detects disc, disc loaded. stop motor.
if button pressed, reverse motor.
if sensor 1 does not detect disc, stop motor.
(there are some else's and stuff missing, but you get the idea).
Oh. The motor is some cheep tiny little thing. Like a small CD-ROM motor basically smiley-razz
Will draw hardly any amps smiley
As for your idea with a relay, would a one shot 555 timer work?
I would rather something programmable :/
« Last Edit: September 19, 2011, 11:50:13 am by Haunted360 » Logged
Offline Offline
Newbie
View Profile
So you want forward/stop/reverse control based on inputs from several transducers. Yes, that would require a micro-controller and an H-bridge, (or a transistor and a relay).  But a simple H-bridge can be constructed from four jelly-bean transistors and is quite a simple circuit.
Would you have a link for me to make the circuit?
Or, would I just use the Arduino and the H-bridge ( http://www.ti.com/lit/ds/symlink/l293d.pdf )??
I am new to this, so no0b based information would be easier to understand.
« Last Edit: September 19, 2011, 05:54:32 pm by Haunted360 » Logged
Offline Offline
Newbie
View Profile
lol. Nice diagram smiley-wink
Underload, I am using 0.28 Amps.
« Last Edit: September 19, 2011, 05:59:06 pm by Haunted360 » Logged
Offline Offline
Newbie
View Profile
PERFECT.
Just what I was after.
Thank you smiley-kitty
Logged
Pages: [1]   Go Up
Print
Jump to:
