Topic: My 20x2 LCD doesnt work properly (Read 5248 times) previous topic - next topic
Dorus
First of all, im Dutch so excuse me for my English if it isnt right.
I bought a 20x2 LCD display with a HD44780 controller on the back of it. I hooked it up to my Arduino and ran some tutorial code to see or it will work. What I get is some not entirely clear to see text, and I can only display up to 7 characters. My question is: Does anyone of you know how to fix this?
Thanks,
Dorus
Some images of my setup and errors and
the code that is running:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
// Command syntax: LiquidCrystal lcd(RS, RW, Enable, D4, D5, D6, D7)
LiquidCrystal lcd(12, 10, 5, 4, 3, 2);
int contrast =0;
int ledpin = 13;
int contrastpin = 2;
  // set up the LCD's number of rows and columns:
contrast = analogRead(contrastpin);
Serial.println(contrast);
//lcd.begin(20, );
  // Print a message to the LCD.
  digitalWrite(ledpin, HIGH);
    digitalWrite(ledpin, LOW);
  lcd.print("123456789");
  lcd.setCursor(0, 1);
liuzengqiang
You need lcd.begin(20,2); in the setup before you can do anything to the display, such as printing to it.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Dorus
Thanks for your quick response, but I already knew I had to start the code with lcd.begin(20, 2);
I already tried to run the code with that in it, but it didnt work either. The only change it made was that the characters where a bit more vague, and thats it. It wasnt an improvement, so I left it out, or should I put it back in?
Or are there other solutions?
Thanks,
Dorus
floresta
Quote
You will not be able to use the second line without it.  The characters were vague since the same contrast voltage will produce different results when the display is set up for two lines vs one line.
Now, getting back to your original problem....
It looks like you are using the Arduino to control the contrast.  Using a value of 0 is the same as connicting pin 3 to GND when you typically want a small positive voltage on that pin.  Also there is a conflict between the pin you appear to be using for the contrast [int contrastpin = 2;] and the pin you are using for LCD data line D7  [LiquidCrystal lcd(12, 10, 5, 4, 3, 2);].
Also, you want to leave loop() empty.  You should move lcd.setCursor(0, 1); to the end of setup() and use another lcd.print() to put some different information on the second line.
If it still does not work then a clear (focused) photograph showing the connections between your LCD and your Arduino will be needed.
Don
Dorus
The readings you see in my code:  contrast = analogRead(contrastpin);  is just to see what the value of my contrast pot was. I hooked pin 3 on the LCD screen, which is defined as C (for contrast) to a potentiometer(10K).
But I will centainly try my code with the void loop() empty, thanks for your response. Ill let you know whether it worked or not.
Dorus
Dorus
I tried running the programme with an empty loop() and also added the lcd.begin(20, 2); And printed something on the second row... which resulted in this.
(See pictures)
It's  not even to see what it should be, so here's the code:
int contrast =0;
int ledpin = 13;
  lcd.begin(20, 2);
  delay(5000);
//contrast = analogRead(contrastpin);
// Serial.begin(9600);
// Serial.println(contrast);
lcd.print("Hi1234");
   lcd.print("Hello");
    lcd.setCursor(0, 2);
Dorus
liuzengqiang
Need to see details of how you connected the lcd to your arduino. I guess some connections were wrong.
Dorus
#7
Sep 20, 2011, 05:37 pm Last Edit: Sep 20, 2011, 05:42 pm by Dorus Reason: 1
I had a former software/hardware designer over at my house, and he checked the pins and they were right. But this guy didnt know the Arduino environment, so he couldnt help me with that.
Could it be, in some way, that the LCD is broken or something? Or that the Arduino doesnt support a 2x20 display? Because I only saw 2x16 in some tutorial videos.
But this is how I connected it:
VSS - GND
VDD - +5V
C - Pot wiper
RS - pin12
R/W - GND (for a 0V)
E - pin10
DB7 - pin2
DB6 - pin3
DB5 - pin4
DB4 - pin5
Abacklight - +5V
Cbacklight -  GND
Dorus
liuzengqiang
all except you should do LCD pin 16-150ohm resistor-gnd. You need the resistor to limit current through the back light. Any amount up to say 2Kohm is good.
Dorus
Ive put a resistor between Cbacklight and the GND, so my wiring should be alright, i guess. Thanks for pointing me at that :). So does anyone know that causes the problems I have?
floresta
You have to set the cursor before you print the data.
Your choices for the line are 0 and 1, not 1 and 2.
Don
Dorus
Don, do you mean like this:
lcd.setCursor(0, 0);
floresta
Yes, except that you want to print more than 9 characters on each line and you want to print different information on the second line.
Don
Dorus
I tried it like this:
lcd.print("Hello World!!!");
lcd.print("123456789101112");
But it didnt work. (Again a picture attached) Could it be that I need to use a different library? Because I read something about the LiquidCrystal440 and the LCD4bit.
liuzengqiang
So essentially the display showed the right characters, more or less, but with some noise. Maybe it is bad. Do you have another display from a different source/store or maybe borrow one from a friend?
