Loading...
Pages: 1 2 3 [4] 5   Go Down
Author Topic: List of your favorite IC's  (Read 3037 times)
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Your opinions??
 It would be a loss (opinion only) if you can't sneak in a fixed 3.3vdc regulator, at least a small TO-92 one for those simple voltage conversion needs that the older arduino boards can't handle well with their 40ma limit on their 3.3 volt pin.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_1323397_-1
« Last Edit: September 28, 2011, 05:53:14 pm by retrolefty » Logged
CO, USA
Offline Offline
God Member
View Profile
Quote
Thought you were going to put some voltage regulators in there?
  Yes.. I will, real soon.. but it probably will be a $5 assortment because there are lots of possibilities, including my personal favorite LM317 which I once bought a barrel of (literally.. but I'd digress if I started that story).
[voice='charlie_brown']
Rats!
[/voice]
Well, I'll still grab the IC assortment, when it's available, and a couple others too.
The LM317 was the SASE deal, which I didn't get around to taking advantage of. smiley-sad
Logged
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
Quote
P.D.Q. Bach concert:  "Prof Schickele plays whatever piano is available. Exclusively"
Oh god... I know of this... and it makes me feel old.
Logged
Topsham, Vermont USA
Online Online
Edison Member
... in The Woods In Vermont
View Profile
WWW
Hi, OK I'm working on the list / prices / availability...
Quote
OK, I will add a couple. Right now I can only get TO220 LM1117 LDO (Cost is 50 cents and that's 10% of my retail target ) ...and some surface-mount, which I am trying to avoid for these packages..
Quote
Hey, you have a long memory  smiley-wink  and now those LM317T's are in USA and I'm in Italy. But the China price is good...
Quote
Compared to who  smiley-roll ?? When I started work at WELI in New Haven USA there were 100% vacuum tubes and the only semiconductor in the entire place was a 1N34A point contact diode in a modulation monitor  smiley
I'll try to get the first-pass list out today...
Logged
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Online Online
Edison Member
View Profile
WWW
Ok, Here's the first-pass on $5 regulator assortment:
Code:
$5 Voltage Regulator Assortment (33 chips)
quantity Part # package description Volts Amps*
2 LM1117-3.3V TO-220 LDO 3.3 0.80
5 7805 TO-220 7800 series 5 1.00
5 78L05 TO-92 7800 series 5 0.20
1 LM2940-5.0V TO-220 LDO 5 1.00
2 7808 TO-220 7800 series 8 1.00
2 7809 TO-220 7800 series 9 1.00
4 7812 TO-220 7800 series 12 1.00
2 7815 TO-220 7800 series 15 1.00
5 LM317T TO-220 adjustable 1.2-35 1.00
5 TO-220 MICA TO-220 Insulator
33 Total Chips
OH, THAT is how you get columns to stay! (almost)..
 I am still trying to find a low-cost 3.3V LDO in TO-92. The other LDO (Low Drop Out in-out voltage difference) regulators add quite a bit to the total cost.
*Current Ratings: Really there is a dissipation rating that is more important for regulators because heat is proportional to the in-out difference voltage. So the published ratings depend on good heat sinking if necessary, and SOME large in-out voltages will never allow the regulator to run at maximum current.
I added some insulators for TO-220.
Comments, suggestions...?? Thanks!
Logged
Online Online
Edison Member
View Profile
WWW
Quote
I prefer the silicone sheet insulators
I agree and the ones I found LOOK like "non-mica" and the supplier had mica as separate product. Looks like this (supplier photo):
Logged
Offline Offline
Newbie
View Profile
Here's a short list of my IC's:
https://docs.google.com/spreadsheet/ccc?key=0Aut0nY7OmVnBdFBDd1A0YnV4cGF5NHdsd0pzVWxqT0E&hl=en_US
I have a bad habit of ordering complete component lists for projects I never even get to start. Over the years, I've horded hundreds of IC's. I recently began to compile a list, which you see on the link. It's a small fraction of the countless unopened bags I have in my room.
Favorite IC: I have to say, the more useful chips are the ones most people take for granted. Yes voltage regulators are quiet useful, but if it were not for those MAX232 chips, I dare say, the early days of our processors would have been very difficult. To this day, they're quiet a requirement on many of our projects.
Logged
Online Online
Edison Member
View Profile
WWW
Hi, I'm still looking for a locally (China) available good Logic level FET to add to the PowerFET assortment.  In a few days after the China holidays and I get some stock, I'll make the assortments available...
Thanks for all the suggestions and help..
Logged
Offline Offline
Newbie
View Profile
Hi Terry,
Here's some Fets that are logic level compatible which I didn't include in my list:
FQD5N20L
IRF634
RLZ34NPBF
FDD7N20
I'm not sure about your rationale behind this...
When starting a project, most newbies usually obtain the parts listed on that particular project instead of using what they have on hand. Getting the project up and running is usually more difficult when using non project-specific parts. Just MHO.
Good luck
Logged
Online Online
Edison Member
View Profile
WWW
Thanks, Mario.. I'll check if I can get those easily..
The idea behind all this is to have a low cost $10 selection of useful devices that could be used in many projects..
Some of us are Parts Junkies  :-)
(Guilty!)
Logged
CO, USA
Offline Offline
God Member
View Profile
Hey, those new assortments are up at the shop!
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=215
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=214
Time to warm up the CC. smiley
Logged
Online Online
Edison Member
View Profile
WWW
Quote
Jeezum Crow! (Vermont-Speak)  I don't even get to announce my own stuff  smiley-razz
 smiley-grin
Actually, we have had some nice deals with a couple of our friendly suppliers. And thanks to many of you here for your suggestions -- always welcome!
Take a look here at all the new goodies: http://arduino-direct.com/sunshop/index.php?l=product_list&c=new
And, take a look over there: http://arduino.cc/forum/index.php/topic,75485.0.html
DISCLAIMER: Mentioned stuff from my own shop..!
DISCLAIMER: Mentioned stuff from my own shop... of course !
« Last Edit: October 15, 2011, 04:39:01 am by terryking228 » Logged
CO, USA
Offline Offline
God Member
View Profile
Hmmm. Not showing USPS as a shipping option. If "CNS FEDEX" in the drop-down = "Local-Country Express ..." might be that's what I want, but I use a different shipping address depending on whether it's coming USPS or some other carrier.
« Last Edit: October 15, 2011, 10:58:00 am by justjed » Logged
Online Online
Edison Member
View Profile
WWW
Shipping is Yet Another Thing of details to learn about!
We had a shipper who did air freight to US and local delivery by USPS (Like CNS-FEDEX does with Fedex delivery), but we had so many problems with 20 day delays in Customs, we stopped using it.  Actual International Post shipping is very expensive.  DHL is good but not cheap. If you can handle 10+ days then HongKongAirmailRegistered seems quite reliable and ends up delivered by USPS..
Anyone with shipping expertise and suggestions please let me know!
Logged
Offline Offline
Newbie
View Profile
Nice one Terry, good prices on them goodies smiley-grin. Any plan for a shop in UK? lol
I am a noob to these things still but I found a couple IC useful (Don't laugh smiley-razz):
MAX1044/ICL7660 Switched-Capacitor Voltage Converters  +5v->-5v 100mA
DM74LS138 3-to-8-line decoders or DM74LS139 2x 2-to-4-line decoders.
5.8Ghz Video transimiter: AWM683 module
5.8Ghz Video reciever:  AWM682 module
Logged
Pages: 1 2 3 [4] 5   Go Up
Print
Jump to:
