Topic: Simple question about the demo projects with the Uno (Read 1 time) previous topic - next topic
DJRikki
Hi there, just got my first Arduino to play with and already built the first two projects to get a feel for things.
My simple question (that is probably very silly) is, why do the tutorials ask me to write up a positive feed to the breadboard when nothing appears to connect to it?
eg:
This type of thing appears in the blinking LED demo from my Sparkfun kit and also the second demo with 8 LEDs.
Many thanks,
Rik
johnwasser
Probably just easier to start with a diagram that has power hooked to the breadboard.  You can ignore the unused power connection.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
BAXX
You dont have to connect positive(red) wire to board. It just there for future use, so far its useless.
radman
Quote
I am glad you asked that question because I was wondering too.
Here are a couple of other newbie questions I hope people will not mind me grafting on here;
  • How did you get the circuit diagram to insert into the post?
  • If I put a continuity meter between the 5V and the GND in your diagram I get a "bell" i.e. short. That is not what I was expecting, but there is probably a very good reason for it which I hope somebody can (simply) explain.
AndyCC
#4
Sep 21, 2011, 12:43 am Last Edit: Sep 21, 2011, 12:46 am by AndyCC Reason: 1
The circuit picture appears to be from Fritzing (fritzing.org).
Measuring continuity (or resistance) when there's power in a circuit is not going to be accurate. The voltage in the circuit can interfere with the voltage the meter sends down the line to check continuity. It's also a good way to fry your meter. Hope this hasn't happened to you!
If you get continuity between +5 and Ground with no power applied... I can't explain that one.
DJRikki
Quote
To put a picture into your post just get its URL and then do this :
Code: [Select]
[img]http://www.aaaaaa.com/picture.jpg[/img]
Texy
...to expand further, you need to upload your photo to your choosen online photo storage site,eg photobucket, etc, then put a link to that photo in your post.
Texy
radman
This has been a really helpful topic for me.
Quote
Fritzing looks like a great way to generate pictures and schematics of sketches, it even shows connectivity and highlights things that are not connected.
Quote
Quote
Code: [Select]
I'll be generating some images with fritzing, putting them on photobucket and embedding them in topics very soon  :)
Quote
I did get continuity without power applied but I was using a very cheap tester. I have borrowed a proper meter and it shows a resistance of about 0.9kohms between +5 and GND. So yes there was continuity but I guess the resistance means its not a short and it represents the power supply circuitry.
Thanks everyone.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
