Topic: IR-Signal 38Khz PWM problem on AtMega2560 (Read 2511 times) previous topic - next topic
Paul_Tonkes
The information is overwhelming when searching this forum, but I still have a PWM problem.
I want to transmit IR signals. I have written two routines, one for setting up a PWM signal (38Khz) and an other for modulating this signal. I worked fine on an Arduino Uno, but there is a problem on the Mega 2560.
First setting up the PWM:
Code: [Select]
static void IR_PWM_INIT(void)
  // Freq.=38Khz. Pulse is 26uSec. ATMega 16 ClockCyclesPerMicrosec. Period = (16 * 26)/2
  #define top  207;
  #define prescaler 1; // Clock niet laten delen door de prescaler. Dit is nit nodig voor deze frequentie
  // PWM output OC2B (PMW-9 defined as output)
  TCCR2A=0;
  TCCR2B=0;
  TCNT2=0;             // Set counter to zero, fresh start.
  ASSR&=~_BV(AS2);     // clock is input for prescaler input:
  OCR2B=top;           // Set Output Compare register.
  TCCR2A=_BV(WGM21);   // CTC-mode: 010 = clear timer on compare match.
  TCCR2B=prescaler;    // 001 = No prescaling
Later I quickly turn on/of the PWM output to modulate the 38Khz signal
Code: [Select]
for(y=0; y<S.TransmitRepeat; y++) // herhaal verzenden IR code
    x=1;
    while(x<=RawSignal[0])
      TCCR2B|=_BV(COM2B0); // turn PWM on
      delayMicroseconds(RawSignal[x++]);
      TCCR2B&=~_BV(COM2B0); // turn PWM off
It worked fine on a ATMega328, but no response on the ATMega2560.
Does anyone have an idea?
johnwasser
Note that the timer output pins are different between Arduino Uno and Arduino Mega.  You are using Timer2.
Timer2A is Pin 11 on the Uno and Pin 10 on the Mega
Timer2B is  Pin 3 on the Uno and  Pin 9 on the Mega
For pin mapping, see:
https://spreadsheets.google.com/spreadsheet/pub?key=0AtfNMvfWhA_ccnRId19SNmVWTDE0MEtTOV9HOEdQa0E&gid=0
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Paul_Tonkes
I noticed that de pin assignment was changed. But I have found the problem! I tried to turn on the PWM with:
Code: [Select]
but TCCR2B is the wrong register, this must be TCCR2A. ]:D
Anyway, thanks!
