Topic: Wireless Aerial Rig (Read 957 times) previous topic - next topic
hexaruby
Sep 21, 2011, 09:35 am Last Edit: Sep 21, 2011, 09:36 am by hexaruby Reason: 1
Hi!
I am trying to send a rig up to the air via a kite (similar to Kite Aerial Photography), bout 60m - 100m. It will be equipped with a wireless camera to send back images/video back. The rig will have 2 modes: manual and auto targeting. The manual mode is whereby the servos will be controlled using the signals from a PS3 controller, while the auto mode will be via the OpenCV platform on my laptop to send signals to the rig to control the servos. All of these are achieved wirelessly.
1) Are all these too much for the arduino to handle? I assume not since the arduino is only handling the wireless signals from the PS3 controller/OpenCV to control the servos?
2) Are there any cheap wireless cameras that has a decent resolution/fps?
3) What will be a suitable way to transmit wirelessly? Wifi/Zigbee? I'm ruling out Bluetooth cos I doubt even a class 1 will be able to transmit the distance required.
Texy
My first arduino project is similair, but just an altimeter, not a video link. I,ve got the principle working, although only tested at about 15-20 meters so far, and this is obviously sending far less data than a video link.
Texy
terryking228
I think most applications like this use a 2.4GHz camera and receiver, not too expensive.
Check out http://diydrones.com
For the Arduino link, maybe these would work: http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
hexaruby
Thanks! I'll check the webbies out. :)
Also if I were to require the servos to react fast (for eg. to adjust the camera so that it goes back aiming at the target asap), is this a software (C code) or a hardware (microcontroller/servo) issue?
hexaruby
#4
Sep 22, 2011, 07:07 pm Last Edit: Sep 22, 2011, 07:17 pm by hexaruby Reason: 1
Just realised it's probably a servo issue since different servos have different angle/second.
One more question, i am trying to control the servos via a playstation 3 controller that is connected to a laptop. Thus, the laptop will take the inputs from the ps3 controller and send them wirelessly to the arduino to control the servos. Is that possible?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
