Topic: Lightsaber sound board. (a what if) can anyone help? (Read 2442 times) previous topic - next topic
jessesproject
Hi guys, I am in the stages of planning a Arduino nano build. I am trying to build a sound board for a lightsaber and if it works I plan on making quite a few.
I want to program the nano to work with a tri-axis accelerometer and play sound files from the Arduino memory or a micro SD card.
I am trying to produce a cheap alternative to existing saber sound boards, with as many features as possible.
Current sound boards are able to
1) play sound 1 on start up or activation, when momentary switch is pushed
2) play sound 2 at idle (nothing happening)
3) play sound 3 when motion is detected (by 3 axis sensor)
4) play sound 4 when activation switch (momentary switch) is pushed for a second time
This is the base for my project if i can do this I hope to elaborate adding more effects.
So what do you think? Is this plausible?
Any input welcomed.
jessesproject
If theres a tutorial that would start me off on the rite direction that would also be appreciated.
techbuilder
#2
Sep 22, 2011, 06:02 pm Last Edit: Sep 22, 2011, 06:09 pm by techbuilder Reason: 1
Here's a start
http://interaction.dundee.ac.uk/~ali/blog/using-the-sparkfunrobertsonics-mp3-trigger-module-with-arduino/
buying a developed board is going to save you quite some time, however this might be to big (2.250"x2.00") but you have an idea
of what to search for, also try searching google for triggering wavs with the arduino. This board uses serial to trigger
MP3s, so it would be quite easy to accomplish what you want by learning the serial functions with the arduino.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
