Loading...
Pages: [1]   Go Down
Author Topic: School project help  (Read 288 times)
Offline Offline
Newbie
View Profile
Hey everyone, we're making an alarm for a school project. We have a problem that we can't solve ourselves.
Here is the code:
http://pastebin.com/sJnD1tpb
We're getting the error code:
Quote
alarm:10: error: expected unqualified-id before 'if'
alarm:15: error: expected unqualified-id before 'else'
Best regards
Logged
New Jersey
Offline Offline
Edison Member
View Profile
All excutable code (apart from variable initialization) needs to be inside a function. Your if statements aren't. To get it to compile you will need to move them inside the loop function. To get it to work, you will, among other things, need to use digitalRead to get the state of your input.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
if(afbryder == 1) {
You've give the constant "afbryder" the value 13.
It is never, ever going to be equal to 1.
As Wildbill said, you need to read the pin.
If you don't want to run "loop", then put all your code into "setup".
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Alright, we tried fixing it, but it still won't work. It compiles fine, but the speaker doesn't turn on.
We tried several different ways, and now we would appreciate some help from outside. Here's what we have right now:
http://pastebin.com/b5dKeu07
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
For short code, it isn't necessay to use pastebin, just use the code tags here.
Code:
void loop () {
      if(digitalRead (afbryder == 0)) {
   //does nothing
} //ends if
else if (digitalRead (afbryder == 1)) {
    digitalWrite(SPKR, HIGH);   // Turns on speaker
    delay(1000);              // Turns on sound for one sec.
    digitalWrite(SPKR, LOW);    // Turns off speaker
    delay(100);              // Waits 100 mili seconds before turning speaker back on
}  //ends loop
"digitalRead" can only return zero or one, if it returns one, then it isn't necessary to test for it returning zero, a simple else will suffice.
Is the speaker really just that?
They don't really like DC.
Code:
void loop () {
      if(digitalRead (afbryder == 1)) {
        for (int i = 0; i < 30000; ++i) {
          delayMicroseconds(500);
}  //ends loop
Edit: Oops, missed this biggy!
Code:
You need to be careful where you put your brackets!
« Last Edit: September 20, 2011, 05:22:24 am by AWOL » Logged
Offline Offline
Newbie
View Profile
Code:
What do you mean by that? Is there something wrong with it?
When you disconnect the wire from "afbryder" the speaker should turn on. That's what we're trying to make, but we can't get it to work properly.
Thanks for the help so far.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Code:
Yes, there's something wrong.
You've given "afbryder" the value 13, so it is never going to be equal to zero, so your digital read will always be from pin zero.
Logged
Offline Offline
Newbie
View Profile
As far as i know, we put "afbryder" to pin 13? Not equal to 13.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
No, look at what you have written - it is the value read from the pin that you want to compare against zero, not the pin number itself.
Your parentheses are in the wrong place.
Code:
if(digitalRead (afbryder) == 0)
Logged
Pages: [1]   Go Up
Print
Jump to:
