Author Topic: Un aiuto con le stringhe............  (Read 347 times)
Ciao a tutti, è da tanto che non programmo seriamente, ma non mi ricordavo che fosse un casino simile manipolare delle stringhe.
Ci ho perso tutta la giornata ma non ne sono venuto a capo.
Sto sviluppando un pde che prende i dati seriali da un GPS e poi se mai dovessi riuscire a manipolare le stringhe, "dovrebbe" compiere determinate azioni in base a quello che gli dice il gps.
Allora, il pde è questo:
#include <string.h>
#include <ctype.h>
#include <SoftwareSerial.h>
#define  MONITORRXPIN    0
#define  MONITORTXPIN    1
#define  GPSRXPIN        8
#define  GPSTXPIN        9
#define  RXBUFFERLENGHT  500
#define  GPRMCCOMMAND    "$GPRMC"
#define  GPGGACOMMAND    "$GPGGA"
#define  GPGSACOMMAND    "$GPGSA"
#define  GPGSVCOMMAND    "$GPGSV"
char   byteGPS = -1;
char   RXBuffer[RXBUFFERLENGHT];
int    CharCount=0;
SoftwareSerial GPSSerial =  SoftwareSerial(GPSRXPIN, GPSTXPIN);
  pinMode(MONITORRXPIN, INPUT);
  pinMode(MONITORTXPIN, OUTPUT);
  GPSSerial.begin(4800);
  InitRXBuffer();
   byteGPS=GPSSerial.read();
   if (byteGPS >= 0)
     RXBuffer[CharCount]=byteGPS;
     CharCount++;
     Serial.print(byteGPS, BYTE);
     if (CharCount >= RXBUFFERLENGHT)
       Serial.print("Errore superamento buffer");
       return;
     if (byteGPS==13)
       CharCount=0;
       InitRXBuffer();
void  InitRXBuffer()
  for (int i=0;i < RXBUFFERLENGHT;i++) { RXBuffer[i] = 0; }
E mi da questo risultato (che è corretto):
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,212320.718,V,,,,,,,230911,,*29
$GPGGA,212321.709,,,,,0,00,,,M,0.0,M,,0000*59
$GPRMC,212321.709,V,,,,,,,230911,,*28
$GPGGA,212322.709,,,,,0,00,,,M,0.0,M,,0000*5A
$GPRMC,212322.709,V,,,,,,,230911,,*2B
$GPGGA,212323.739,,,,,0,00,,,M,0.0,M,,0000*58
$GPGSV,3,1,10,20,75,047,,23,65,203,,32,48,072,,24,40,141,*74
$GPGSV,3,2,10,17,34,270,,31,26,056,,11,25,157,,04,20,309,*70
$GPGSV,3,3,10,14,13,044,,10,01,272,*78
$GPRMC,212323.739,V,,,,,,,230911,,*29
$GPGGA,212324.709,,,,,0,00,,,M,0.0,M,,0000*5C
$GPRMC,212324.709,V,,,,,,,230911,,*2D
$GPGGA,212325.709,,,,,0,00,,,M,0.0,M,,0000*5D
$GPRMC,212325.709,V,,,,,,,230911,,*2C
$GPGGA,212326.718,,,,,0,00,,,M,0.0,M,,0000*5E
$GPRMC,212326.718,V,,,,,,,230911,,*2F
$GPGGA,212327.709,,,,,0,00,,,M,0.0,M,,0000*5F
$GPRMC,212327.709,V,,,,,,,230911,,*2E
$GPGGA,212328.709,,,,,0,00,,,M,0.0,M,,0000*50
Il testo viene scritto byte per byte in seriale e sembra funzionare, però se tiro via la riga che scrive
byte per byte e provo a fargli scrivere l'array, il risultato non è lo stesso:
#include <string.h>
#include <ctype.h>
#define  GPSRXPIN        8
#define  GPSTXPIN        9
#define  RXBUFFERLENGHT  100
int    CharCount=0;
  InitRXBuffer();
   char   byteGPS = -1;
   if (byteGPS >= 0)
     CharCount++;
//   Serial.print(byteGPS, BYTE);   ************** commentato riga che scrive byte per byte
       return;
     if (byteGPS==13)
    // **************** aggiunto ciclo for che scorre l'array e invia alla seriale un carattere per volta
     for (int i=0; i <= strlen(RXBuffer)-1; i++)
         Serial.print(RXBuffer[i], BYTE);
     Serial.println("");
       CharCount=0;
       InitRXBuffer();
void  InitRXBuffer()
Ho evidenziato le righe modificate/aggiunte.
Il risultato è questo:
,,,*1E
GSV,3,1,11,23,85,194,,20,61,082,,04,36,306,,32,34,085,*7B
f23,148,,31,19,041,,13,14,224,*7A
3f14,282,,11,09,159,,30,00,028,*48
21,V,,,,,,,230911,,*26
$GPGGA,220354.713,,,,,0,00,,,M,0.0,M,,0000*51
,,,,,*1E
RMC,220354.713,V,,,,,,,230911,,*20
$GPGGA,220355.713,,,,,0,00,,,M,0.0,M,,0000*50
,,,,,*1E
RMC,220355.713,V,,,,,,,230911,,*21
$GPGGA,220356.721,,,,,0,00,,,M,0.0,M,,0000*52
,,,,,*1E
RMC,220356.721,V,,,,,,,230911,,*23
$GPGGA,220357.713,,,,,0,00,,,M,0.0,M,,0000*52
,,,,,*1E
RMC,220357.713,V,,,,,,,230911,,*23
$GPGGA,220358.713,,,,,0,00,,,M,0.0,M,,0000*5D
,,,,,*1E
13,V,,,,,,,230911,,*2C
$GPGGA,220359.721,,,,,0,00,,,M,0.0,M,,0000*5D
,,,,,*1E
RMC,220359.721,V,,,,,,,230911,,*2C
$GPGGA,220400.713,,,,,0,00,,,M,0.0,M,,0000*57
,,,,,*1E
RMC,220400.713,V,,,,,,,230911,,*26
$GPGGA,220401.713,,,,,0,00,,,M,0.0,M,,0000*56
cf
$GPRMC,220401.713,V,,,,,,,230911,,*27
$GPGGA,220402.721,,,,,0,00,,,M,0.0,M,,0000*54
,,,,,*1E
RMC,220402.721,V,,,,,,,230911,,*25
$GPGGA,220403.713,,,,,0,00,,,M,0.0,M,,0000*54
,,,,,*1E
13,V,,,,,,,230911,,*25
$GPGGA,220404.713,,,,,0,00,,,M,0.0,M,,0000*53
,,,,,*1E
RMC,220404.713,V,,,,,,,230911,,*22
$GPGGA,220405.724,,,,,0,00,,,M,0.0,M,,0000*56
,,,,,*1E
RMC,220405.724,V,,,,,,,230911,,*27
$GPGGA,220406.715,,,,,0,00,,,M,0.0,M,,0000*57
,,,,,*1E
RMC,220406.715,V,,,,,,,230911,,*26
$GPGGA,220407.715,,,,,0,00,,,M,0.0,M,,0000*56
,,,,,*1E
RMC,220407.715,V,,,,,,,230911,,*27
$GPGGA,220408.723,,,,,0,00,,,M,0.0,M,,0000*5C
,,,,,*1E
23,V,,,,,,,230911,,*2D
$GPGGA,220409.715,,,,,0,00,,,M,0.0,M,,0000*58
,,,,,*1E
RMC,220409.715,V,,,,,,,230911,,*29
$GPGGA,220410.715,,,,,0,00,,,M,0.0,M,,0000*50
,,,,,*1E
RMC,220410.715,V,,,,,,,230911,,*21
$GPGGA,220411.724,,,,,0,00,,,M,0.0,M,,0000*53
,,,,,*1E
RMC,220411.724,V,,,,,,,230911,,*22
$GPGGA,220412.715,,,,,0,00,,,M,0.0,M,,0000*52
,,,,,*1E
RMC,220412.715,V,,,,,,,230911,,*23
$GPGGA,220413.715,,,,,0,00,,,M,0.0,M,,0000*53
,,,,,*1E
15,V,,,,,,,230911,,*22
$GPGGA,220414.724,,,,,0,00,,,M,0.0,M,,0000*56
,,,,,*1E
RMC,220414.724,V,,,,,,,230911,,*27
Mi sono fatto l'idea che nel primo caso, viene scritto byte per byte in tempo reale, mentre nel secondo
il tempo che arduino impiega a scorrere l'array e a printarlo in seriale fa passare dei cicli di cpu in cui
il gps continua ad inivare dati che vanno persi perchè non scaricati dal buffer.
Però, se il problema è veramente questo, come potrei risolverlo?
La prova di scrittura dell'array l'ho fatta non perchè mi serva stamparlo a video tramite seriale, ma perchè
non risuscivo a capire come mai mi era impossibile manipolare le strinche con strcmp e strcpy.
Se qualcuno ha qualche dritta smiley
Grazie.
Ciao.
"La teoria è quando si sa tutto ma non funziona niente. La pratica è quando funziona tutto ma non si sa il perché. In ogni caso si finisce sempre con il coniugare la teoria con la pratica: non funziona niente e non si sa il perché." Albert Einstein
Penso anche io che il tuo problema sia la software serial. Prova ad abbassare il baud rate della software serial e a portare quello della seriale vera a 115200, così hai meno tempi morti.
P.S. L'IDE di arduinio ha messo a disposizione una classe apposita per le stringhe. Se hai da manipolarle pesantemente ti conviene dargli un'occhiata. Il link è questo: http://arduino.cc/en/Reference/StringObject
Mi è venuta a mente un'altra cosa (guarda, stavo per andare a letto, sono tornato al pc apposta  smiley-grin ). Se fosse il problema della software serial, la prima stringa in teoria dovrebbe stampartela correttamente... Fammi sapere.
Forum Moderator
Don't know what I do
Non conosco le librerie in oggetto ma mi pare che ci sia un errore logico di fondo, ossia il tuo codice dovrebbe/vorrebbe fare questo:
1) inizializzo le comunicazioni col GPS e la Seriale->PC
2) mi metto in attesa e ricevo i dati eventualmente spediti dal GPS mettendoli in un array
3) nel momento in cui leggo il byte 13 (carattere invio, presumo), stampo sulla seriale->PC i dati raccolti
4) reinizializzo il buffer di ricezione e mi rimetto in ascolto
Ecco, il problema sono i puntoi 3 e 4, secondo me.
Col punto 3 tu ti metti ad inviare i dati verso il PC ma il GPS non continua a spedirti i dati verso l'Arduino? A me pare di sì.
Dopo che hai spedito l'array al PC, tu al punto 4 reinizializzi il buffer di ricezione, ma così cancelli i dati che avevi ricevuto dal GPS fino a quel momento. Così poi ti metti in ascolto in un punto imprecisato della comunicazione, per mandare i dati ancora al PC appena arriva un carattere 13.
BZ (I)
+39 349 2158303
non usare  la libreria
SoftwareSerial.h
ma la newsoftseria arduiniana.org/libraries/newsoftserial/
poi per leggere un byte usa il controllo se ci sono dati presenti con
if (device1.available() > 0)
    int c = device1.read();
Ciao Uwe
Grazie, non sapevo di questa classe per le stringhe.
Per quanto riguarda la velocità della seriale, posso sicuramente aumentare quella che va vero sil pc a 115200 ma non ho trovato nulla per cambiare la velocità del gps.
Si, la prima la riceve correttamente a parte un carattere ascii casuale all'inizio dovuto forse a qualche spuria.
Inoltre, se io gli faccio printare via seriale ogni byte che riceve, vedo tutti i dati correttamente.
Ma finchè io non ho printato tramite il ciclo for tutto l'array e non l'ho inizializzato, il ciclo di loop non è finito e qundi le istruzioni che scaricano i dati seriali e li mettono sul buffer non vengono eseguite...................o sbaglio?
SoftwareSerial.h
Ciao Uwe
Provo a studiarmi newsotseriale e vediamo se risolve.
Grazie smiley
Forum Moderator
Ma la seriale implementata nell'Arduino ha un buffer di 128 byte. Se arrivano più dei 128 byte, i vecchi dati vanno persi, sovrascritti dai nuovi. Usare la NewSoftSerial può aiutarti nel senso che la libreria riceve i dati dal buffer di Arduino anche quando il tuo codice non fa una lettura esplicita però devi sempre tenere a mente il limite dei 128 byte. Puoi provare ad alzarlo modificando il file HardwareSerial.cpp nel core di Arduino però poi diminuisci la memoria SRAM a disposizione del programma.
« Last Edit: September 24, 2011, 03:08:18 am by leo72 » Logged
Grazie a tutti dei consigli.
NewSoftSerial ha risolto il problema alla grande smiley
SoftwareSerial.h
Ciao Uwe
specifichiamo: la softserial NON usa gli interrupt, quindi se arrivano dati mentre non stai facendo una read(), vengono persi per sempre. Invece sia la seriale harware che la NewSoftSerial parcheggiano i dati in arrivo, anche se stai facendo altro, in un buffer, da cui potrai leggeri con calma.
ovvio rimane il "piccolo" problema dell'overflow del buffer, spiegato da leo72, ma a meno che tu non faccia calcoli pazzesci o uso di delay, non dovrestiincappare nel problema
my Arduino code: https://github.com/lestofante/arduinoSketch
sei nuovo? non sai da dove partire? leggi qui: http://playground.arduino.cc/Italiano/Newbie
