Topic: Press button action. And press and hold button action (Read 2036 times) previous topic - next topic
chadpriddle
Sep 24, 2011, 11:09 pm Last Edit: Sep 24, 2011, 11:12 pm by chadpriddle Reason: 1
I'm creating a simple program that just handles 2 keystrokes on the keyboard with the press of the same button.
I want the a keystroke for when the button is just pressed and I want a different keystroke for when the button is pressed and held for 5 seconds.
  pinMode(10, INPUT_PULLUP);
  delay(4000);
  if (digitalRead(10) == HIGH) {
    Keyboard.print("Button Held For 5 Seconds");
    delay(5000);
    Keyboard.print("Button Presses Once");
  delay(10);
I've looked on the forums and can't find anything simple like this. My only other solution is to have 2 separate buttons but id' like to stick with only one.
Thanks in advanced
olikraus
#1
Sep 24, 2011, 11:36 pm Last Edit: Sep 24, 2011, 11:40 pm by olikraus Reason: 1
1. Do not use delay()
2. Learn to construct state machines
How can i teach you to create a state machine? There are many resources on the web, maybe this one:
http://www.splatco.com/fsm_tute/fsm_tute01.htm
I also have my own tutorial online:
http://code.google.com/p/m2tklib/wiki/t05
Let me try to make a small tutorial with your example:
a) identify the inputs
--> button, values are pressed and not pressed
--> additionally we need a timer and a signal for this timer: target time reached
b) identify the outputs
--> action 1 and 2
--> and for the timer: start timer (calculate target time)
c) identify the states
State 1: button not pressed, wait for button pressed
State 2: button is pressed, but target time not reached AND button is still pressed
State 3: button is not pressed and target time has not been reached --> action 1, goto State A
State 4: button is not pressed and target time has been reached --> action 2, goto State B
Exercise: Use a paper and draw the four states. Use a circle or box to represent the state.
Draw arrows for all possible state changes. Next to the arrows write the condition for which the state change can occur.
Example:
State 1  ----- button is pressed ------> State 2
Finally do the implementation
int state = 1;
switch(state) {
  case 1:
    if ( /* button is pressed */ )
      state = 2;
      target_time = millis() + 5000;
    break;
Got the idea? Maybe you can share your state machine with us.
Oliver
naweston
chadpriddle -
I am just begging my first project using arduino as well. My project is very similar to yours, though mine is a tad bit simpler. I am super new at this but here is what I am wanting to code for.
4 button momentary footswitch wired to Teensy board.
Button 1 pressed --> sends KEY_ENTER
Button 2 pressed --> sends KEY_SPACE
Button 3 pressed --> sends KEY_UP
Button 4 pressed --> sends KEY_DOWN
I am lost as to where to being: assigning pins and action states, etc. SUPER NEWB!
a.d
To the original poster - http://jmsarduino.blogspot.com/2009/05/click-for-press-and-hold-for-b.html
chadpriddle
Thanks for the replies! I followed the link and was able to customize it to my application:
#define buttonPin 10 // analog input pin to use as a digital input
#define debounce 20 // ms debounce period to prevent flickering when pressing or releasing the button
#define holdTime 1500 // ms hold period: how long to wait for press+hold event
// Button variables
int buttonVal = 0; // value read from button
int buttonLast = 0; // buffered value of the button's previous state
long btnDnTime; // time the button was pressed down
long btnUpTime; // time the button was released
boolean ignoreUp = false; // whether to ignore the button release because the click+hold was triggered
// Set button input pin
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH );
// Read the state of the button
buttonVal = digitalRead(buttonPin);
// Test for button pressed and store the down time
if (buttonVal == LOW && buttonLast == HIGH && (millis() - btnUpTime) > long(debounce))
btnDnTime = millis();
// Test for button release and store the up time
if (buttonVal == HIGH && buttonLast == LOW && (millis() - btnDnTime) > long(debounce))
if (ignoreUp == false) event1();
else ignoreUp = false;
btnUpTime = millis();
// Test for button held down for longer than the hold time
if (buttonVal == LOW && (millis() - btnDnTime) > long(holdTime))
event2();
ignoreUp = true;
buttonLast = buttonVal;
// Events to trigger by click and press+hold
void event1()
Keyboard.print(" "); // pressed once
void event2()
Keyboard.set_key1(KEY_ESC); // pressed and held
Keyboard.send_now();
Keyboard.set_key1(0);
