Topic: Powering a 12V motor with an external power source. (Read 964 times) previous topic - next topic
laptopman
So I am integrating a 12v motor into my arduino circuit. I am using an ~10v power supply for the motor, and I need that power not to be diverted to the arduino+other components. How can I wire the motor to a transistor controlled by pwm while having the arduino powered by a separate 9v source? The trouble I am having right now is that the voltage I receive from the transistor is equivalent to the voltage I am supplying to the base (and I am not mixing up collector/base)
I'm using a standard TIP120 transistor
Grumpy_Mike
Quote
Sounds like you have wired it up as a common collector circuit and not a common emitter circuit.
See:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
terryking228
Hi, The connections to the Tip120 are not what I consider "In Order"  :)
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
laptopman
I realize that but I followed the circuitry diagram on the packaging so i think I got it right.
Grumpy_Mike
Quote
Are you just talking about the pinout?
Can you post a schematic of how you have wired the transistor, I still think you are using an emitter follower with the load connected between emitter and ground, this is not the way to drive your motor.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
