Author Topic: Read Xbee Address  (Read 412 times)
Looking for a way to read an XBee Address or ID using an Arduino so that I can uniquely identify where a string is originating from without having to have a separate program installed on each Arduino.
Has anyone done this before? Is it possible?
Brian
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
Sure is. I use S2 XBees in API mode with Andrew Rapp's library. Goes something like this here...
#include <XBee.h>              //http://code.google.com/p/xbee-arduino/
ZBTxRequest zbTx;
ZBRxResponse rx = ZBRxResponse();
zbTx.setAddress64(rx.getRemoteAddress64());    //return to sender
zbTx.setAddress16(0xFFFE);
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Thanks. I have started looking at the API. However, since I am sending from an Arduino to a Connectport X2, I can't have arduino code running on the Connectport (ZB Coordinator) to return the senders address.
I need to find a way to get the address from within the local board. Does that make sense?
Seattle, WA USA
Seattle, WA USA
You could upload a sketch to the Arduino that stores a string in EEPROM. Change the string for each Arduino. Then, upload the sketch that the Arduino should run for real, that gets the string from EEPROM, and prepends it to any string sent.
Sure, use ATSH and ATSL to get the 64-bit address, or ATMY to get the 16-bit address. The latter is only unique within the network, but I'd think that'd be good enough for a lot of purposes.
PaulS also makes a good suggestion, I do something similar, only I use the XBee Node Identifier. I set a unique NI in each XBee, then the program interrogates it and inserts it into the transmitted data.
Seattle, WA USA
Seattle, WA USA
How do you do this? A code snippet, please.
Hope this isn't too snipped up. I use X-CTU to set the NI (and also AP=2). The getXBeeNI() function gets called once from setup(). The readXBee() function gets called from loop() continuously to check for incoming traffic, and has a switch statement to check for various incoming packet types, one of which is a response to AT commands.
XBee xbee = XBee();                                       //XBee object
void getXBeeNI(void) {
    union {byte B; char C;} atCmd[3];
    AtCommandRequest atCmdReq;
    strcpy(&atCmd[0].C, "NI");
    atCmdReq = AtCommandRequest(&atCmd[0].B);
    xbee.send(atCmdReq);
void readXBee(void) {
    AtCommandResponse atResp;
    union {byte B; char C;} xbeeNI[9];                     //XBee node identifier
    byte respLen, *resp;
    xbee.readPacket();
    if (xbee.getResponse().isAvailable()) {                //incoming traffic
        switch (xbee.getResponse().getApiId()) {           //what kind of packet did we get?
        case ZB_RX_RESPONSE:                               //rx data packet
        case ZB_TX_STATUS_RESPONSE:   //tx status
        case AT_COMMAND_RESPONSE:                          //response to AT commands
            atResp = AtCommandResponse();
            xbee.getResponse().getAtCommandResponse(atResp);
            if (atResp.isOk()) {
                respLen = atResp.getValueLength();
                resp = atResp.getValue();
                for (int i=0; i<respLen; i++) {
                    xbeeNI[i].B = resp[i];
                xbeeNI[respLen].B = '\0';
                Serial.print(millis(), DEC);
                Serial.print(" XBee NI=");
                Serial.println(&xbeeNI[0].C);
            else {
                Serial.println("XBee AT CMD ERROR");
            break;
« Last Edit: September 27, 2011, 06:35:43 am by Jack Christensen » Logged
Seattle, WA USA
Seattle, WA USA
It's fine. Thanks. I'll have to have another look at the XBee library. When I have time...
