Topic: how to insert a code panel into a forum posting (Read 1 time) previous topic - next topic
jcarrr
Where ar the instructions for inserting a quote or code panel in to a forum posting?
johnwasser
There is a menu of symbols above the edit box but for some reason it doesn't work on the Safari browser.
To put in a quote use the tags quote and /quote in SQUARE BRACKETS.
To put in code, use the tags code and /code in square brackets.
To quote an entire post, click on the "Quote" link in the upper right of the post.
To insert a quote after you have started replying, click on the "Insert Quote" link at the top right of the post/reply you want to quote.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
jcarrr
Thanks,
It should be simple but I did it wrong the first try.  If I survive the criticism I will do it properly next time
JC
PaulS
#3
Sep 28, 2011, 03:13 pm Last Edit: Sep 29, 2011, 03:23 pm by PaulS Reason: 1
Quote
Having made an attempt, even if wrong, will minimize the criticism. Having made an attempt to learn the proper way works even better.
By the way, you CAN edit (modify) a post, and correct your attempt.
robtillaart
Quote
By the way, you CAN edit a post, and correct your attempt.
And that is the modify option (Paul you can change that in your post too :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Coding Badly
And now for the pretty graphical version...
Please click Modify ( or ) on your post, select the source code, click the button above the edit window, then click .
