Topic: 1.5v motors not working (Read 1 time) previous topic - next topic
ahhreeyell
I just soldered some wires to my 1.5v motors and stuck them into a breadboard being powered by four double A batteries, but they aren't working. I did a pretty sloppy job soldering them, but when I checked the connections using my multimeter, it clearly said they were receiving 3.25 volts. Any ideas why this could be happening?
zoomkat
Still could be bad solder joints, bad batterys (four good batterys should produce ~6v total when in series), bad wiring, etc..
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
MarkT
Have you measured the resistance between the motor terminals when unpowered?
jackrae
Dead motors ?  You say you are providing power from 4 x AA batteries (6 volts) yet you say the motor terminals reads 3.25 volts.  This suggests you motor shaft is seized causing the motor to draw excessive current and overloading the batteries.  Even if you had dry solder joints, the motors should still run IF they have >1.5 volts on them
MarkT
You could measure the current (only if your multimeter has an amps range - milliamps is not enough).  A stalled motor may draw a fair bit of current, 0.3 to 2A perhaps?  Normal values perhaps 0.1A.
Putting 6V onto a 1.5V motor will rapidly burn out the commutator in my experience.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
