Topic: MLX90614 Infrared Thermometer Module No Signal (Read 1 time) previous topic - next topic
patcc2
I'm attempting to hook up the MLX90614 Infrared Thermometer Module sold by parallax to the Arduino Uno but the sensor's serial pin is outputting no data eg. -1 when casted as a int.
I've attempted to follow the instructions from: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1241012329 with absolutely no success.  I copy and paste the raw code changing absolutely nothing and have triple checked my wiring to the sensor and everything matches up with what the data sheet says but still no output.  I think my sensor is failing the PEC test but as far as i can tell their is no way to test this theory.  Also i've tried using multiple digital pins on my Arduino so im 99.99% sure that the problem is not the digital pins on my Arduino.  Lastly i checked the sensors analog I2C signal pin connected to the PIC chip on the module and found a signal at a very fast baud rate followed shortly after by the serial pin signal coming from the module.
RIDDICK
#1
Oct 03, 2011, 11:25 am Last Edit: Oct 03, 2011, 11:27 am by RIDDICK Reason: 1
have u seen this datasheet?
http://www.sparkfun.com/datasheets/Sensors/Temperature/MLX90614_rev001.pdf
do u have pullup resistors on ur SCL/SDA lines?
did u try to use it in PWM mode?
-Arne
zarifeh
Hello
I use MLX90614 and I can read the temperature from adress 0x07. Now I want to change the emissivity in 0x04 of EEPROM.I tried to change it but I think my sensor now does not work properly.please help me in this case
thanks
patcc2
No I have the module version from parallax.  http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/infrared/List/0/SortField/4/ProductID/539/Default.aspx
The signal is converted from a I2C to a Serial TTL on the module using a pic chip and some other components.  Looking at the module data sheet they put pull up resistors on the circuit the signal is just not being properly sent back to my Arduino.  I'm not sure if the address are responding to my command prompts.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
