Loading...
Poll
Question: Is a 9.6V 2000mAh battery ok to power my arduino uno board?
Yes - 1 (100%)
No - 0 (0%)
Total Voters: 1
Pages: [1]   Go Down
Author Topic: External Power for Arduino Uno  (Read 643 times)
Offline Offline
Newbie
View Profile
Hi everyone. I am very new to the world of microcontrollers so I barely know anything. I have a quick question: Is a 9.6V 2000mAh battery ok to power my arduino uno board? And I would just have to connect the ground and the positive wires directly into the arduino ground and Vin pins right? I want to make sure before I do it so as not to burn up my board. Thank you for taking your time to help out a complete noob.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
It all depends what is connected to the board , a few servos or relays will draw more than 10 LED's (depending on type of LED smiley-wink
Add up all what is connected for a particular project and you can compare it to the battery.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Thanks a lot for the help. I really appreciate it.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Yes, it will work...depending on what you're going to connect to it. If you try to suck maximum current out of every Arduino pin then you might run into problems.
PS: Poking a wire into the Vin connector will work but you'll get a much solid connection with a proper power connector plug.
Logged
Pages: [1]   Go Up
Print
Jump to:
