Topic: function to generate a PPM output? (Read 9695 times) previous topic - next topic
rahlk
How to create a function which generates a ppm pulse as a RC would? i want this function to be running in the background untill i change it.
what changes do i need to make to the following code?
Code: [Select]
void ppm_gen(int pin, int speed) {
digitalWrite(pin, HIGH);
delayMicroseconds( speed);
digitalWrite(pin, LOW);
delay(20);
From what i can understand this function will run only once and the control will return to the calling function.
But to run a servo the loop should run over and over again.
If my understanding correct, what changes should i make?
Grumpy_Mike
rahlk
Yes but the refresh rate is 30Hz, very low for my liking.
I need to run an ESC for a bldc. I need it to be atleast 200 - 250Hz.
AWOL
#3
Oct 01, 2011, 02:49 pm Last Edit: Oct 01, 2011, 02:51 pm by AWOL Reason: 1
An RC ESC will expect PPM at 50Hz (which is the frame rate the servo library works at, not 30Hz).
Is this not an RC ESC?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Techone
@rahlk
Let me understand what you are asking... I read about servos, a PWM @ 50 Hz is slow for you, OK so you need PWM @ 200 to 250 Hz instead , correct ?  OK Let analyse a PWM ... @ 50 Hz Period = 1/50 = 0.02 s  or 20 ms @ 200 Hz Period = 1/200 = 0.005 s or 5 ms.  So a PWM is changing Ton vs Toff  , therefore Ton < Toff --> < 50 %  Ton > Toff --> > 50 %   Ton = Toff --> 50 %.... Follow me so far...So your program have to reflect that. So if you whant the speed to increase, Ton have to increase  -->  Speed /\ Ton  Lower speed , lower Ton Speed \/ Ton.
Here an example of a code of a PWM @ 1000 Hz. Hope it help.
Code: [Select]
// Compile and Tested
byte PWMpin = 11;
byte vpin=0;
int vin=0;
int period=1000; // 1 kHz = 1 / Period in uS
int timeA;  // time on
int timeB; // time off
  pinMode(PWMpin, OUTPUT);
  vin=analogRead(vpin);
  timeA=map(vin,0,1023,0,period); // calculate time on
  timeB=period-timeA; // calculate time off
  digitalWrite(PWMpin, HIGH);
  delayMicroseconds(timeA);
  digitalWrite(PWMpin, LOW);
  delayMicroseconds(timeB);
AWOL
#5
Oct 01, 2011, 07:10 pm Last Edit: Oct 01, 2011, 07:12 pm by AWOL Reason: 1
@Tech one,
RC equipment uses PPM, not PWM
Your arithmetic looks...suspect.
Techone
#6
Oct 01, 2011, 07:13 pm Last Edit: Oct 01, 2011, 07:32 pm by Techone Reason: 1
@AWOL
PPM is ? Pulse ? Modulation ...
edit again :
Quote
What you mean my math look "suspect" ?    My technical writting skills is not that great you know.
Edit :
PPM = Pulse Position Modulation
Like this site : [urlhttp://www.simplecircuitdiagram.com/2009/05/20/pulse-position-modulator-using-555-ic/][/url]
So in the program you simply keep Toff constant.  You simply figure out @ lower frequency the Ton and @ higher frequency the Ton with a constant Toff using speed has a variable to change Ton.
Erni
@Techone
If you want to know the difference between ppm and pwm :
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253149521/all
AWOL
#8
Oct 01, 2011, 08:23 pm Last Edit: Oct 02, 2011, 09:39 pm by AWOL Reason: 1
[font=Verdana][/font]@Tech one
"20ms @ 200Hz" doesn't make a great deal of sense.
Yes, low duty cycle PWM looks a lot like PPM.
However, unless you use very high resolution PWM (I.e. greater than 8 bit), your active PPM period (< 10%) is going to have very poor resolution.
However (again) RC gear is designed to run at a frame rate of 50Hz, so simply shortening the frame time may not work at all.
Maybe the OP is confusing the ESC's control input PPM rate with its output PWM frequency.
Techone
#9
Oct 02, 2011, 02:29 am Last Edit: Oct 02, 2011, 02:32 am by Techone Reason: 1
@AWOL
Quote
I mean ---> AT 200 Mz Period = ..... I forgot a DOT after 20 ms
I mean : @ 50 Hz Period = 1/50 = 0.02 s  or 20 ms
Opps ...  :smiley-red:
Sorry that I sound confusing sometime.
I just trying to help the OP.  Anyway, RC is Remote Control ?  and ESC ?
In a program to generated a PWM or PPM, you still need to control Ton, Toff and the Period.
Edit:
@Erni
Thank for the link. Interresting.
rahlk
@AWOL
Quote
Yes it is an RC ESC. Some wise men around told me this refresh rate of 50Hz is not good for an RC ESC and it runs best at 200Hz and a max of 300Hz.
Thanks for the link from Erni, and from a "GOD" member MEM. I figured that the servo does run from a ppm pulse after all. The ON time varies from 1000 Microseconds to 2000 Microseconds with the OFF time being constant at 20 milliseconds. So my initial snippet was correct. But all this, they still don't answer my question- what should I do to have this function running in the background untill it's changed.
retrolefty
Quote
You just need to use the standard Arduino servo library. You write a value to it and it automatically continously sends it out to the servo (read ESC) input at the proper rate until you write a new value. This is handled by interrupts but you don't have to do anything for that to happen.
Lefty
zoomkat
Some reading on ESCs.
http://www.google.com/search?q=arm+esc+site%3Ahttp%3A%2F%2Farduino.cc%2Fforum%2Findex.php&hl=en&num=100&lr=&ft=i&cr=&safe=images
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
AWOL
I don't know your 'wise men', but I'd say they are not terribly experienced with RC gear.
If an ESC is designed for RC, then it EXPECTS PPM with a frame time of 20ms.
This is the frame rate used by digiprop RC gear for at least the last 30 years.
It may not work well at different frame rates.
Servos frequently don't.
The output frequency may well be much higher, as I mentioned earlier.
Or maybe you simply misunderstood the wise men.
retrolefty
Quote
That's my guess, wise men often speak in strange tongues.  ;)
