Topic: function to generate a PPM output? (Read 7988 times) previous topic - next topic
Techone
@rahlk
Let me get this...  A ON time of 1000 us or 1 ms to 2000 us or 2 ms.   And a OFF time of 20 ms.  You say you need 200 Hz to 300 Hz.   All right , let figure out the frequency using the Ton and Toff.
@ Ton = 1 ms or 1000 us
Toff = 20 ms
1 / Period  = Frequency  ---->  1 / ( 1 ms + 20 ms ) = 47.61904762 Hz
@ Ton = 2 ms or 2000 us
Toff = 20 ms
1 / Period = Frequency  ----->  1 / ( 2 ms + 20 ms ) = 45.454545...... Hz
My question is : Where the 200 Hz to 300 Hz come from ? The problem is the 20 ms, it make the frequency slower.
My calculation is saying that a 50 Hz servo system will work. So can you try the servo library and see what happen ?
My 2 cent.
rahlk
@ AWOL and Lefty-
Okay I got this. Screw the wise men (maybe they aren't that wise after all..).
Servo library works like a charm!
But here's what I did.. I used:
Code: [Select]
// The channel 2 of my receiver is connected to pin 5 of my Arduino Mega.
Serial.print(pulseIn(5, HIGH));
Serial.print("                ");
Serial.println(pulseIn(5,LOW));
delay(50);
I noticed that pulseIn(5, HIGH); gives a value around 1049 to 1899 (As i gradually move the throttle stick up)
and a separate pulseIn(5, LOW); gives a value from 18900 to 17900 (again as i move the throttle stick up)
In essence this isn't a ppm (which according to many people must have a constant Toff period of 20ms).
It theoretically is a pwm pulse, which has a variable duty cycle.
So what does a servo library generate anyway, eh?
?•? ?Á??l ?•?
Grumpy_Mike
Quote
But PWM has a constant period which your experiments are not showing anyway.
Quote
I would say the Ton has to be the constant one.
It looks like the high part is supposed to be constant but is drifting a bit.
Anyway it is much more like PPM that PWM.
rahlk
Quote
i guess it is a constant PERIOD pulse. If I do this:
Code: [Select]
Serial.printLN(pulseIn(5, HIGH)+pulseIn(5,LOW));
The value does 'NOT' change.
?•? ?Á??l ?•?
Grumpy_Mike
Quote
OK so you have PWM, it is not the right way to drive a servo, but some servos will make sense of it.
justone
A nice little video showing ppm and pwm .
http://www.youtube.com/watch?v=L7KLLTv3hbw
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
