Topic: rfid Card acknowledgement (Read 962 times) previous topic - next topic
maddave
Hi there… I have a rfid reader and  a XBee pro shield from cooking-hacks.com. when I pass a card over the reader the red led flashers can I tell it to send voltage to a pin when this happens …..thanks
Grumpy_Mike
Quote
Yes but only if you connect the signal flashing the red LED to an arduino (or something else)
You question is a bit vague, so it matches my answer.
For a more specific answer please provide links to the equipment yo are using, along with how you are wiring it up to the Xbee. It would also be useful to know what you want to do.
Most RFID readers have a separate input to flash the red LED because you normally want to flash the red when you deny access and green when you grant it.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
