Topic: VU meter with peak hold (Read 7067 times) previous topic - next topic
thelukewarm
Hi, I am trying to do a VU meter with a "peak hold" effect in a 12LED bar like this one http://www.youtube.com/watch?v=AWiVHym2jKQ and I already have the VU meter code but I can't make the peak hold effect, my main problem is that I don't know how to store the analog value so that the Arduino leaves the peak led HIGH while it continues reading the audio input.
I'm not very experienced on this stuff so any suggestions will be helpful  :smiley-yell:
My code is this:
void setup (){
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
void loop (){
int value = analogRead(A0);
value = map (value, 0, 127, 0, 12);
switch (value) {
case 0:
  digitalWrite(2,LOW);
  digitalWrite(3,LOW);
  digitalWrite(4,LOW);
  digitalWrite(5,LOW);
  digitalWrite(6,LOW);
  digitalWrite(7,LOW);
  digitalWrite(8,LOW);
  digitalWrite(9,LOW);
  digitalWrite(10,LOW);
  digitalWrite(11,LOW);
  digitalWrite(12,LOW);
  digitalWrite(13,LOW);
  delay(20);
case 1:
  digitalWrite(2,HIGH);
  delay(20);
case 2:
  digitalWrite(3,HIGH);
  delay(20);
case 3:
  digitalWrite(4,HIGH);
  delay(20);
case 4:
  digitalWrite(5,HIGH);
  delay(20);
case 5:
  digitalWrite(6,HIGH);
  delay(20);
case 6:
  digitalWrite(7,HIGH);
  delay(20);
case 7:
  digitalWrite(8,HIGH);
  delay(20);
case 8:
  digitalWrite(9,HIGH);
  delay(20);
  case 9:
  digitalWrite(10,HIGH);
  delay(20);
  case 10:
  digitalWrite(11,HIGH);
  delay(20);
  case 11:
  digitalWrite(12,HIGH);
  delay(20);
  case 12:
  digitalWrite(13,HIGH);
  delay(20);
Magician
similar topic:
http://arduino.cc/forum/index.php/topic,73935.0/topicseen.html
CrossRoads
Instead of switch(value), try this.
create an ledarray for the pins:
ledarray[2,3,4,5,6,7,8,9,10,11,12,13];
then before reading again, keep the prior analog read:
if (value>oldvalue){
oldvalue = value;
next read the analog pin, and write  the bargraphs:
for (x=2 to value){
digitalWrite (ledarray
  • , HIGH);
    next x;
    if (value<13){
    for (x=(value+1) to 13){
    digitalWrite(ledarray
  • , LOW);
    next x;
    if (oldvalue>value){  // keep the high LED lit up
    digitalWrite(ledarray[oldvalue], HIGH);
    highvaluecount = highvaluecount-1;  //provide a way for it to fall back down
    if (highvaluecount ==0){
    oldvalue = oldvalue-1;
thelukewarm
Thanks, now I am able to keep the oldvalue HIGH but I can't make it go down, I think I need a delay to make the "go down one by one effect" visible to the eye but when I use it all the program gets affected by the delay and the analogRead becomes out of sync. Here's what I've got if you can help me:
int pinArray[] = {2,3,4,5,6,7,8,9,10,11,12,13};
int valor=0;
int oldvalue=0;
void setup (){
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
void loop (){
if(valor>oldvalue){
   oldvalue=valor;
valor = analogRead(A0);
valor = map (valor, 0, 127, 0, 12);
for(int i=0; i<=valor; i++){
  digitalWrite(pinArray, HIGH);
if (valor<13){
   for(int i=valor+1; i<=13; i++){
     digitalWrite(pinArray, LOW);
if(oldvalue>valor){
digitalWrite(pinArray[oldvalue], HIGH);
oldvalue=oldvalue-1;
delay(100);
macegr
Create another global variable and use it to maintain a counter that tracks the number of loop executions. After so many, decrement the value controlling the visible level. That's the code-efficient way to do it.
Or if you want it to be time-accurate, at the expense of messing with LONG types, use the millis() timer to trigger a regular decrement ala BlinkWithoutDelay example.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
Magician
May be you'll find it helpful:
http://docs.macetech.com/doku.php/rusty_vu
robtillaart
hint:
Code: [Select]
void setup ()
for(int i=2; i<=13; i++) pinMode(pinArray[i] ,OUTPUT);
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
thelukewarm
#7
Oct 10, 2011, 05:34 am Last Edit: Oct 10, 2011, 05:39 am by CrossRoads Reason: 1
Sorry I forgot about this post XD I kinda solved the problem counting the number of times the Arduino reads de code and after a lot of reads the peak LED goes down by one, here's the code if someone is interested and thanks :)
Code: [Select]
int pinArray [] = {2,3,4,5,6,7,8,9,10,11,12,13};
int valor=0;
int valoranterior=0;
int x=0;
void setup (){
void loop (){
if(valor>valoranterior){
valoranterior=valor;}
int p=0;
if(p=900000000){
  valor=valor/900000000;
  p=0;}
switch (valor) {
case 0:
 delay(20);
case 1:
 delay(20);
case 2:
 delay(20);
case 3:
 delay(20);
case 4:
 delay(20);
case 5:
 delay(20);
case 6:
 delay(20);
case 7:
 delay(20);
case 8:
 delay(20);
 case 9:
 delay(20);
 case 10:
 delay(20);
 case 11:
 delay(20);
 case 12:
 delay(20);
if(valoranterior>valor){
digitalWrite(pinArray[valoranterior-1], HIGH);
p=p+1;
x=x+.001;
if(x=2000000000){
valoranterior=valoranterior-1;
delay(20);}
robtillaart
Quote
int p=0;
if(p=900000000){
   p=0;}
think 9000000 is out of range for an int, => use long
and the if condition should be  ==  iso  =
my 2 cents,
Rob Tillaart
dangnoi
Dear Guy, Can I apply to ATMEL microcontroller? AT89Cxxxx and do you mind if I need you help to show the example of source code.
robtillaart
The forum is here to ask questions and help each other so post your questions, include your code sofar, tell about the goal of the project, the hardware used, schematics, and tell as much as you can about the problem encountered. What did you expect and what did you got. The more you tell the better answer you can expect.
Rob Tillaart
