Topic: Another Audio Spectrum Analyzer. (Read 16644 times) previous topic - next topic
mundosimaginados
Oct 02, 2011, 10:14 pm Last Edit: Oct 11, 2011, 04:20 pm by El Artis Reason: 1
My last project is an audio spectrum analyzer. The work has been done using a MSGEQ7 integrated. The result is shown using an 2X16 LCD display. The bars are built using defined characters.
The chip only gives 7 info of frequency. I've arrived until the 16 bar interpolating values based in the 7 given.
The music you hear is a them I wrote in 2005.
http://www.youtube.com/watch?v=EpLLqgySCD4
http://www.mundosimaginados.com
http://mundosimaginados.blogia.com
robtillaart
Well done and quite responsive,
can you share code & schematics?
Rob Tillaart
Onions
That's pretty cool! You've tempted me to set one up myself some time... I know it is possible to use transistors with a resistor ladder to produce one bar of the EQ thingy (can't think of how to phrase it, so I'll draw the schematic). Do you have any codes? :D
There, badly drawn and missing LED series resistors, but it should work as an EQ thingy. :)
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
mundosimaginados
I don't have an schem but you can find here info about how conect: http://nuewire.com/info-archive/msgeq7-by-j-skoba/.
And here is my code:
#include <LiquidCrystal.h>
// The LCD is conected to pins 13,12,11,10,9,8
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
byte vumetro[8][8];
float vumetros[16];
// The analog pin 0 is used to read value.
int valor_analogico = 0;
// The 6 & 7 pins are used for control the integrated.
int strobe = 6;
int reset = 7;
int valores_frecuencias[7];
  // Built the characters for bars.
  for (int j=0; j<=7; j++)
    for (int i=0; i<=7; i++)
      if (i<=j)
      { vumetro[j][7-i] = B01110;}
//      { vumetro[j][7-i] = B01010;}  Uncomment this lines for getting other variants for bars.
//      { vumetro[j][7-i] = B11111;}
      { vumetro[j][7-i] = 0;}
  for (int i=0; i<=7;i++)
    lcd.createChar(i, vumetro[i]);
  lcd.begin(16, 2);
  for (int j=0; j<=7;j++)
    lcd.setCursor(j, 0);
    lcd.write(j);
    lcd.setCursor(j, 1);
    lcd.write(7);
  pinMode(valor_analogico, INPUT);
  pinMode(strobe, OUTPUT);
  pinMode(reset, OUTPUT);
  analogReference(DEFAULT);
  digitalWrite(reset, LOW);
  digitalWrite(strobe, HIGH);
  digitalWrite(reset, HIGH);
  // The read of integrated is done by multiplexing.
  for (int i = 0; i < 7; i++)
    digitalWrite(strobe, LOW);
    delayMicroseconds(5);
    valores_frecuencias[i] = analogRead(valor_analogico);
// It's necesary to interpolate for calculating 16 bars having only 7 values read.
for (int k=0; k<=15; k++)
  switch (k)
    case 0:
      vumetros[k]= valores_frecuencias[0]/64;
      break;
    case 1:
      vumetros[k]= (valores_frecuencias[0]/64 + valores_frecuencias[1]/64)/2;
      break;
    case 2:
      vumetros[k]= valores_frecuencias[1]/64;
      break;
    case 3:
      vumetros[k]= (valores_frecuencias[1]/64 + valores_frecuencias[2]/64)/2;
      break;
    case 4:
      vumetros[k]= valores_frecuencias[2]/64;
      break;
    case 5:
      vumetros[k]= (valores_frecuencias[1]/64 + valores_frecuencias[2]/64 + valores_frecuencias[3]/64)/3;
      break;
    case 6:
      vumetros[k]= (valores_frecuencias[2]/64 + valores_frecuencias[3]/64 + valores_frecuencias[4]/64)/3;
      break;
    case 7:
      vumetros[k]= random(2)+valores_frecuencias[3]/64;
      break;
    case 8:
      break;
    case 9:
      break;
    case 10:
      vumetros[k]= (valores_frecuencias[3]/64 + valores_frecuencias[4]/64 + valores_frecuencias[5]/64)/3;
      break;
    case 11:
      vumetros[k]= valores_frecuencias[4]/64;
      break;
    case 12:
      vumetros[k]= (valores_frecuencias[4]/64 + valores_frecuencias[5]/64)/2;
      break;
    case 13:
      vumetros[k]= valores_frecuencias[5]/64;
      break;
    case 14:
      vumetros[k]= (valores_frecuencias[5]/64 + valores_frecuencias[6]/64)/2;
      break;
    case 15:
      vumetros[k]= valores_frecuencias[6]/64;
      break;
  Dibuja_vumetro(k, vumetros[k]);
  delay(2);
void Dibuja_vumetro(int posicion, int altura)
  if (altura>7)
    lcd.setCursor(posicion, 1);
    lcd.write(7);
    lcd.setCursor(posicion, 0);
    lcd.write(altura-8);
    lcd.write(altura);
    lcd.write(32);
willnue
Very cool!
I really am glad I had a copy of J Skoba's tutorial saved (for my own benefit) and now since I reposted it even happier to see others benefit as well.
willnue
mundosimaginados
Thanks you for posting the tutorial. I decided to start my develop seeing the post you saved...
Zyrusthc
http://fritzing.org/projects/msgeq7-audio-equalizer/
http://fritzing.org/projects/sparkfun-spectrum-shield-audio-equalizer-lcd/
Have create on this Thread and http://nuewire.com/info-archive/msgeq7-by-j-skoba/
