Topic: Holes too small on my PCB - now what? (Read 2538 times) previous topic - next topic
xberg
I proudly just received my 1st self-designed PCB, but alas, some holes are too small. I had 6x 3.5mm stereo jacks on the PCB (they have 5 pins each) but did not notice that the pins are larger than the typical resistor or IC - no matter how hard I push I can't get all 5 pins in (and have already broke 2 components in trying!).
Is there a cheap tool I could use to make the holes just that bit larger? I have 30 holes to work on so hopefully something that won't take an hour her hole!
thanks,
XBerg
terryking228
hi, is your board double-sided?? If you were to solder only the solder-side of your board, would you have all connections?
If you don't NEED the plated-through holes for circuit connectivity, just drill the holes out with a just-big-enough drill??
Other remote possibility: a long tapered pin or "awl" MIGHT be able to deform the holes/board just enough?
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
macegr
Can you clip or crush the pins into a narrower shape?
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
MarkT
You now know why datasheets provide all the dimension data as well as electrical data (!)
jackrae
Clock-makers broaches are ideal for making small holes just a little larger.  Because you work (twist) them by hand there is minimal fear of things getting "out-of-hand" so to speak --- excuse the pun.
xberg
Thank you all for the friendly replies - much appreciated.
Yes - it's a double sided PCB. I'm try with a small tool to make them bigger - not much risk as the place where I ordered sent me 10 PCB and I only need 1, so great to experiment.
Terry - is through-hole plating that important for connectivity, as opposed to just the copper ring around the hole?
thanks,
XBerg
pwillard
could be a problem if you cannot solder the top side, due to being covered by a component and it is used in a connection path.
jackrae
You may be able to overcome losing the through-hole connection by drilling the hole oversize and slipping in a piece of tinned copper wire.  Bend the ends so's it makes contact with the circuit runs and solder into place before fitting the component.
dc42
If you do need the through-hole connections, then after drilling them out you may be able to solder the component leads on both sides of the board, if there is room to get at them on the top side. I have seen this done on autopilot circuit boards made in the 1970s before plated-through holes became common.
