Author Topic: Max capacity external memory RAM  (Read 1270 times)
Hi everyone! I am working in a project about realiable wireless communication, and I need a external memory for store data when the Arduino is out of range. So, my question is very simple. Does anybody know which is the bigger memory RAM that i can add to the arduino? Because the biggest that i found it was 23K256 (32KB), and this is too small. Thanks!
ruggedcircuits.com
How much memory do you need and how fast do you need to access it?
We have a MegaRAM shield for the Arduino Mega/Mega2560 that adds 128kilobytes of fast RAM. You can get more storage if you move to FLASH memory, or use a shield that has an SD card interface in which case megabytes or even gigabytes of RAM become accessible, but it is slower to write to these media.
Tell us more about your desired memory size and speed of access.
The Basic Motor Driver: simple, inexpensive motor driver for 1 stepper motor or 2 DC motors
Rapa Nui
Pukao hats cleaning services
..You may try ramtron's FRAM FM25H20 (256kBytes, SPI 40MHz, 8pin smd). It works as a ram, and you get a bonus as it is nonvolatile.. Pito.
« Last Edit: October 03, 2011, 03:44:42 pm by pito » Logged
There is a device IP12B512C serial SRAM with 64Kbyte available.
See www.ipsilog.com
Manchester (England England)
Solder is electric glue
Yes in theory it is infinite, now how big do you need it to be?
1 megabyte.
4 megabytes would be even better.
I need low-latency read/write access to large amounts of memory for audio applications. It's a shame no one makes a board that supports this.
Well this looks good:-
http://uk.farnell.com/bsi-brilliance-semiconductor/bs62lv1600eip55/sram-16m-2mx8bit-3v-55ns-tsop44/dp/1488953
Well it's not the memory that produces the limit on access speed (assuming that is what you mean by latency*) It is the things you have to do to generate the address bus and data bus to support the part. You will need a fist full of port expanders and getting data into and out of those will increase the effective memory access time.
They would if they thought there was a market for it.
*Latency is the time between a trigger and the action and the word is normally used to indicate the responsiveness of something in human terms.
I'm aware such chips exist. My question was who makes a board that can interface with the Arduino.
Yes that is the concept I speak of.
The delays associated with initializing a read/write operation to SD cards are be unacceptable for real-time audio applications.
« Last Edit: November 15, 2011, 11:52:21 am by relaxing » Logged
No it was not, your original question was:-
You did not ask about who makes a board you said which is the bigger memory RAM that i can add to the arduino?
Was the phrase:-
accompanied by any more information, like I don't want to design it myself I want to buy something someone has already made. If so I missed it.
So that doesn't make sense in relationship to memory access of external RAM. It would only make sense if accompanied with things like sampling rate and number of memory accesses per sample. It is not an inherent function of any particular access architecture.
Netherlands
A naughty mind is a joy forever.
Maybe you should check who... wrote what.
If so I missed it.
You didn't miss it. You specifically addressed it one of your posts with a smarmy, off-the-cuff appeal to market economics.
What are you talking about? Latency is absolutely a quality that applies to RAM, independent of how I access it.
« Last Edit: November 18, 2011, 01:12:32 pm by relaxing » Logged
nr Bundaberg, Australia
How fast do you need? IIRC the AVR will do a native access to the external RAM pretty quick, there may be a wait state inserted I can't remember. But every time you change pages you will have to write to a port and if the access is random you will also have to test the upper N bits of the address for every access
OTOH if the access is in say 32k bursts you can just blat the data out with no address tests.
______
Rob
I'm looking at audio playback with no human-detectable latency... so I need reads of say 8 words to complete in ~1ms.
I only brought up latency because that rules out external flash cards. I think external RAM should be able to handle the latency requirements easily.
The issue is getting access to enough of it... like a 4 Mbyte chip would be golden.
