Topic: using PIR Sensor to fading LED (Read 6468 times) previous topic - next topic
arduinoOK
when the PIR throws HIGH the LED strobes.  When the PIR throws LOW it fades while strobing repeatedly
PaulS
Not sure what you mean by "strobes". If the fading is not smooth, there is a problem with your LED or how it is wired.
arduinoOK
I messed with my hardware a bit and It was my LED going bad... Now the LED stays solid when the PIR throws HIGH and fades (as it should) but now it cycles through the fade when the PIR throws LOW
PaulS
Have you changed the code so that firstLEDvalue has different values when the PIR throws HIGH and when it throws LOW? If not, then the behavior you are seeing is expected.
arduinoOK
Thanks for the help so far but I still haven't found a solution to this...
AWOL
arduinoOK
I finally figured it out!  XD
const int firstLED = 3;      // pin for the LED
const int inputPin = 2;      // input pin for the PIR sensor
int PIRstate;               // variable to hold the last PIR state
int val;                    // variable for reading the pin status
  pinMode(inputPin, INPUT);              //declare PIR as input
  PIRstate = digitalRead(inputPin);      //assign PIR state to PIRstate
  val = digitalRead(inputPin);      // read input value
  if (val != PIRstate)                      // check if the input has changed
    if(val == HIGH){
      analogWrite(firstLED, 255);
    else{
      for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
        // sets the value (range from 0 to 255):
        analogWrite(firstLED, fadeValue);
        // wait for 30 milliseconds to see the dimming effect
        delay(30);
  PIRstate = val;                 // save the new state to the variable
DDRYA
This post was super helpful.. however the only problem I am encountering (which im assuming is going to be a 'duh' moment when someone responds) but how do i set up my PIR? I am using an UNO... i had the 5v lead of PIR in 5v of arduino, ground in GND and the 'OUT' lead of PIR in digital pin 2... but I get nothing at all?
DDRYA
haha YES!!! thank you! life saver!!!!
