Topic: Hacking the Info Globe (Read 2144 times) previous topic - next topic
blackrockcity
So i picked up an Info Globe http://www.youtube.com/watch?v=-sfR5de5gck, and the board that sends the communications to the rotor via IR LED communication has died, the rotor still spins and im assuming gets power. This seems like the only info on hacking these devices available online... http://www.linux-hacker.net/InfoGlobe/ hes using this code: http://linux-hacker.net/InfoGlobe/Infoglobe_hack.asm and a PIC16F84 with 4.0 MHz resonator master oscillator. Is there anyway to convert this code for arduino to process it and output code via LED IR to communcate with the infoglobe? or should i obtain one of these  PIC16F84 and go from there? oh and im new, whats a  4.0 MHz resonator master oscillator?
blackrockcity
http://www.lima.com.tr/BasicTiger/Applications/PDF/appn_071e_The%20magic%20globe.PDF or is there anyway to emulate page 8 of that pdf through arduino?
CrossRoads
Technically, anything is possible.
Might be tricky converting PIC assembly into AVR assembly, different registers & such, but not impossible.
ams0178
I've used both AVRs and PICs. I like them both. If you're just starting out and have no preference, I'd go with the PIC. Same low cost hobbyist tools and there are free C compilers I'd recommend using unless you want to use assembly. And you might be able to use his code as a better reference if you're using a PIC. If you have any specific questions feel free to PM me or ask here. Alan
blackrockcity
Would love to know how you did it.. I had a universal power supply i connected to it with the wrong polarity set (so stupid). So I think i fried the board. I dont think i fried the rotor, but its possible, the thing still spins and illuminates the red battery light when batteries are not isntalled, when i first powered it on it worked, then started to display garbled characters.. anyway my end game its to emulate the board and send signals to the LED IR, is there any way to at least send a message to the rotor to just turn on the leds via arduino and a LED IR?
ams0178
My development process? I didn't actually do this same process. I'm referring to PIC and AVR based projects using my own custom PCBs. I could explain more of the embedded development process I use if you're interested. I just recommended a PIC for you because that's what the guy used in your first post. Using a PIC would alleviate replicating his code elsewhere.
Alan
estranged
I gave this a try about a year ago, working off the same PIC based tutorial you found. I managed to get a little further than you. I was able to send it basic letters most of the time, but never anything very long and I'd say that only about 70% of the characters got transmitted correctly. I chalked it up to not really understanding all the timings, and sort of figured that what I really needed was a scope measuring the signals as they went back and forth so that I could adjust my timings.
For what its worth, here's my hacked up working sketch. I'll see if I can find the globe still and maybe take a picture of my base IR short and my replacement IR setup.
int ir_pin = 8; //Sensor pin 1 wired through a 220 ohm resistor
int led_pin = 12;    //"Ready to Receive" flag, not needed but nice
int debug = 1;    //Serial connection must be started to debug
int start_bit = 2400; //Start bit threshold (Microseconds)
int bin_1 = 0;    //Binary 1 threshold (Microseconds)
int bin_0_start = 760;      //Binary 0 threshold (Microseconds)
int bin_0 = bin_0_start;      //Binary 0 threshold (Microseconds)
int bin_0_tweak = 0;      //Binary 0 threshold (Microseconds)
int searchSize = 30;
int dataOut = 0;
int guardTime = 0;
int loopCount = 0;
int switchPin = 10;
bool lastSwitchState;
bool currentSwitchState;
bool ledState;
pinMode(led_pin, OUTPUT); //This shows when we're ready to recieve
pinMode(ir_pin, OUTPUT);
digitalWrite(led_pin, LOW); //not ready yet
digitalWrite(ir_pin, LOW);   //not ready yet
pinMode(switchPin, INPUT);
lastSwitchState = digitalRead(switchPin);
ledState = LOW;
   checkButton();
int sendIRKey(int dataOut) {
  int data[8];
digitalWrite(led_pin, HIGH);     //Ok, i'm ready to send
for (int i=0; i<8; i++)
   //data[i] = dataOut >> (i & B1);   //encode data as '1' or '0'
   if (dataOut & (B1<<i)) {
     data[i] = 1;
     data[i] = 0;
// send startbit
// oscillationWrite(ir_pin, start_bit);
// send separation bit
//digitalWrite(ir_pin, HIGH);
//delayMicroseconds(guardTime);
// startTime = millis();
// send the whole string of data
for (int i=7; i>=0; i--) {
   //digitalWrite(ir_pin, LOW);
   //if (data[i] == 0) delayMicroseconds(bin_0);
   //else delayMicroseconds(bin_1);
   if (data[i] == 0) {
      oscillationWrite(ir_pin, bin_0);
     // oscillationWrite(ir_pin, bin_1);
     delayMicroseconds(1010 - bin_1);
   // Serial.print(data[i]);
   // digitalWrite(ir_pin, HIGH);
   // delayMicroseconds(guardTime);
endTime = millis();
duration = endTime - startTime;
Serial.print(' ');
Serial.print(duration);
Serial.println();
digitalWrite(led_pin, LOW);     //done sending
// return dataOut;     //Return key number
// this will write an oscillation at 38KHz for a certain time in useconds
void oscillationWrite(int pin, int time) {
for(int i = 0; i <= time/26; i++) {
   digitalWrite(pin, HIGH);
   delayMicroseconds(13);
   digitalWrite(pin, LOW);
void checkButton() {
  currentSwitchState = digitalRead(switchPin);
  Serial.println(currentSwitchState);
  if (currentSwitchState != lastSwitchState) {
    if (currentSwitchState == LOW) {
      // button depressed
      sendSignal();
    delay(50);
  lastSwitchState = currentSwitchState;
void sendSignal() {
   sendIRKey(0x01);
   //sendIRKey(0x48); // H
   //sendIRKey(0x49); // I
   sendIRKey(0x45); // E
   sendIRKey(0x4C); // L
   sendIRKey(0x4F); // O
   sendIRKey(0x20); //
   sendIRKey(0x57); // W
   sendIRKey(0x52); // R
   sendIRKey(0x44); // D
  bin_0_tweak++;
  if (bin_0_tweak > searchSize) {
    bin_1++;
    if (bin_1 > searchSize) {
      bin_1 = 0;
    bin_0_tweak = 0;
  bin_0 = bin_0_start - bin_0_tweak;
  Serial.print("bin_0: ");
  Serial.print(bin_0);
  Serial.print("   bin_1: ");
  Serial.println(bin_1);
  delay(100);
putyn
just an idea - wouldn't be easier to take the circuit from the globe out and build your own circuit around an atmega328 which will control the leds and the motor :) ?
