Austin, TX
Offline
Full Member
I make my own electricity.
« Reply #15 on: October 09, 2011, 06:02:59 pm » |
I wrote my first programs in the mid-70's, and started getting paid to do it in the late 70's. I think we've both been at this software thing a really long time.
If 830 KB/sec isn't fast enough, you really need a faster processor anyway -- memory shuffling is one thing, processing the memory you shuffle takes a bit more work. Even if there was no overhead in doing the memory transfer, you'd get something like 40 clocks per byte read and written at 16MHz. FWIW, the first processor I worked on executed about 90,000 instructions per second.
I'm still in early production for a Modbus-enabled product that will initially be based on an Arduino and a signal conditioning board I'll have laid out in the next week or so. If the product makes me money, I'll spend more money to make it better. As for the code, have keyboard, will travel -- I have over 30 years of kernel experience. I trust my code, and the best thing about my code -- I don't have to pay someone else royalties to ship it.
Logged
Rapa Nui
Offline
God Member
Pukao hats cleaning services
« Reply #16 on: October 10, 2011, 06:01:18 am » |
830kB/sec r/w is great for most applications arduino hobbists run! I wish I get a compiler which can compile into an external ram and to run code out of it!! AFAIK the IAR compiler can compile code to external ram of atmegax. @jfhaugh: when talking 70's - have a look at "retrobsd.org" - 2.11bsd runs on pic32mx (chipkit MAX32 board supported as well), it uses an sdcard for root partition and swap. We can write ~300-600kB/sec and read ~1-1.5MB/sec to the sdcard (it depends on sdcard used). I guess it outperforms most PDP-11 versions from 70's. We are looking for contributors as well. ]  P.
« Last Edit: October 10, 2011, 06:11:23 am by pito »
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #17 on: October 10, 2011, 08:43:58 am » |
pito,
You can use existing libraries and device code with a RTOS. You just need to use the proper task structure with queues, semaphores, and mutexes to get sharing to work.
Currently I am playing with FreeRTOS and ChibiOS/RT. I like ChibiOS/RT for ARM but FreeRTOS is a better choice for avr Arduino.
Using a preemptive kernel takes knowledge/skill for proper use so it's not for beginners.
Logged
Rapa Nui
Offline
God Member
« Reply #18 on: October 10, 2011, 09:54:08 am » |
fat16lib, I would be happy to see an example of using default arduino libs with an rtos, indeed  . I've ran chibios on my stm32vl discovery modules (the demo, I overclocked them, both 48MHz stable, one module 56MHz stable). So not bad for $10 gadget  . P.
Logged
SF Bay Area (USA)
Online
Faraday Member
Strongly opinionated, but not official!
« Reply #19 on: October 10, 2011, 10:33:51 am » |
I would say you cannot use the existing libraries (ie i2c, spi, uart, etc.) for an rtos easily - you need to rewrite those as you need none blocking ones, you need to control a concurrent access to them from several tasks/threads, etc. This is the issue - my understanding is all drivers need to be redone The real question at this point is whether the APIs that have been defined by Arduino are reasonable if you suddenly put an operating system (let's skip the "RT" part for now; IMO, RT is overrated and ... really hard) underneath. Mind you, it's not at all easy to do microcontroller-like things on top of an operating system. bit-banging I2C out a couple of general purpose IO pins becomes a choice of whether you want to move excessively slowly (by blocking) or have the functions take longer than you'd like. Ditto software-serial and SPI, though at a byte level; some things can be moved to interrupts, but the SPI hardware present on an AVR is still byte-at-a-time. Doing really well under an OS means you need DMA or highly buffered and intelligent controllers for each perpheral, and the AVRs don't have them. (some of the 32bit CPUs might.) But pretty soon you end up with WINCE, .NET, or Android, where IO pins are no longer directly accessible, flexibility is lacking, latency sucks, and you need an (old-style) arduino-class board (with no OS) to play with real hardware. Fine if you want a micro web server that copies stuff from SD card to TCP, but lousy at driving that big LED matrix thing or doing retro electronic gaming... You could do a "proof of concept" on an old linux PC. digitalWrite() out the parallel port, etc...
Logged
Athens, Vienna
Offline
Newbie
Embedded Software Specialist
« Reply #20 on: October 11, 2011, 02:18:33 am » |
Concerning the existing libraries and an (RT)OS: The solution which would most likely deliver the best results performance wise would IMHO be a rewrite of the current libraries, but there is more than one way to skin a cat. The solution with the highest degree of reuse-ability of existing libraries would most likely be just a "partial rewrite" which comes with some performance trade offs. This solution is what the DruinOS people had in mind. In the Microchip AppNote AN1264 is more information about how this could be done: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en544728Regards, Robert
Logged
Rapa Nui
Offline
God Member
« Reply #21 on: October 11, 2011, 04:01:01 am » |
..the simplest rtos approach is offered by some compilers - for example CCS for PIC. Simple, included, consist of 13 functions, cooperative.. http://www.ccsinfo.com/downloads.php#manualsp.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #22 on: October 11, 2011, 10:16:59 am » |
It's not that hard to use FreeRTOS. I downloaded FreeRTOS and did a few edits to make it compatible with Arduino. I made FreeRTOS an Arduino library, AvrFreeRTOS. It took about an hour. Below is my test sketch with two tasks. One that writes data to an SD and one that blinks an LED. Next I will replace the LED sketch with one that reads a sensor and queues the data to the SD sketch. The queue will provide buffering so no data points are lost during the SD write. The sensor sketch will run at higher priority than the SD sketch. #include <AvrFreeRTOS.h> #include <SdFat.h>
SdFat sd; SdFile file;
#define LED_PIN 3
static void vLEDFlashTask(void *pvParameters) { for (;;) { vTaskDelay(150); digitalWrite(LED_PIN, HIGH); vTaskDelay(50); digitalWrite(LED_PIN, LOW); } }
static void vSdTask(void *pvParameters) { for (;;) { vTaskDelay(1000); file.println(millis()); file.sync(); } }
void setup() { int r; Serial.begin(9600); pinMode(LED_PIN, OUTPUT);
xTaskCreate(vLEDFlashTask, (signed portCHAR *)"Task1", configMINIMAL_STACK_SIZE + 100, NULL, tskIDLE_PRIORITY + 2, NULL); Serial.println(r); xTaskCreate(vSdTask, (signed portCHAR *)"Task2", configMINIMAL_STACK_SIZE + 300, NULL, tskIDLE_PRIORITY + 1, NULL); if (!sd.init()) sd.initErrorHalt(); file.open("RTOS.TXT", O_WRITE |O_CREAT);
vTaskStartScheduler(); }
void loop() { // Insert background code here }
Logged
Centurion RSA
Offline
Full Member
Arduino rocks
« Reply #23 on: October 12, 2011, 12:49:11 am » |
Has anyone used the ThreadKit rtos? I would like to see some sample code using com ports and interrupts.
Logged
Rather people think you to be a fool than you open your mouth and confirm it.
Rapa Nui
Offline
God Member
« Reply #24 on: October 12, 2011, 11:33:15 am » |
@fatlib16: what happens when you not use vTaskDelay() functions in a task (or in both)?p.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #25 on: October 12, 2011, 06:43:33 pm » |
Marius,
ThreadKit is not a RTOS, it is an implementation of extremely lightweight stackless threads. As such, it's response to interrupts is much more limited than a preemptive kernel. What do you expect to see in sample code?
Pito,
A key function of a preemptive RTOS is to control which task has the CPU. A task can release the CPU in a number of ways. Common ways for a task to block without using the CPU are to delay, wait on a message queue, or wait on a semaphore.
If a task never blocks the standard thing for a preemptive RTOS happens. If the task is the highest priority it starves all other tasks. If two tasks at the same priority don't block they will run round-robin in many RTOSes.
In my example there are three tasks. The highest priority is the LED task, next is the SD task, and finally loop(), the idle task.
If you remove vTaskDelay from the LED task, it will use 100% of the CPU blinking the LED as fast as possible.
If you remove vTaskDelay from the SD task but leave vTaskDelay in the LED task, the LED will run as before but the SD task will write to the SD as fast as possible with CPU time not used in the LED task and loop() will get no CPU time.
As you can see you should avoid calls to the Arduino delay() in high priority tasks. Fortunately the Arduino core has no delay calls.
Logged
Austin, TX
Offline
Full Member
« Reply #26 on: October 12, 2011, 09:55:03 pm » |
pito,
You can use existing libraries and device code with a RTOS. You just need to use the proper task structure with queues, semaphores, and mutexes to get sharing to work. MAYBE they can work. Unless there's a way to set a task to "INT_MAX" or disable rescheduling, there are things that are going to break badly. Like, bit-banging on a communications port. Leaving Tx high for longer than a bit clock is a BAD idea.
Logged
SF Bay Area (USA)
Online
Faraday Member
« Reply #27 on: October 12, 2011, 10:58:52 pm » |
or disable rescheduling This is one of the advantages of a run-to-completion operating system ("cooperative multitasking"); a task isn't blocked unless it explicitly asks to be blocked, so you can still do little timing-critical loops and such. (in ONE task, anyway. This wrecks "somewhat critical timing" in other tasks. The thing is, a fair number of things that one typically does with "small" microcontrollers are really dependent on NOT having an operating system in there mucking with your timing. You can look at the history of the IBM PC and see it "mature." The original DOS was more of a program loader and file manager than real operating system, but you could implement your own ISRs, or twiddle the bits on the parallel port to do neat things. When windows came out at about the same time that higher speed modems became affordable, companies started having to ship Serial port cards with deeper FIFO, because the OS introduced too much latency (time with ISRs disabled) and the older UARTs dropped characters; but you could still write your own "user space" drivers. In the WXP derived OSes you lose direct access to hardware devices and have to rely on the OS drivers... It's easy to mistake "real time" to mean "fast", when in fact it has a lot more to do with determinism. I remember being really unimpressed with announcements out of some BBN research project back in the late 80s. It seems that their latest operating system on their expensive DoD funded Internet thing could guarantee response to a packet within 1ms. At the time we (cisco) were processing 12000 pps on much cheaper HW; 1ms seemed like a joke. (Later, I came to understand that cisco's OS didn't come close to being able to offer any such guarantee, even though "typical" throughput was very much higher...) (Similarly, there used to be a lot of people that believed in Token Ring Networks over Ethernet because TRs were more deterministic. In both cases, determinism ended up losing in the market...) Most OSes are pretty RAM-intensive, making them a poor match for most microcontrollers that have very limited RAM. The AVRs are particularly annoying because the ratio of "context" for a task to the total amount of RAM is quite high. (~35 bytes of context, 2K of RAM on a m328) So it would be nice to define how the arduino core and libraries are supposed to behave in cooperating with hypothetical operating systems. It might have to be done twice; once for "real time preemptive" operating systems, and again for more generic OSes...
Logged
Centurion RSA
Offline
Full Member
Arduino rocks
« Reply #28 on: October 12, 2011, 11:44:08 pm » |
Well maybe just to see how a receive procedure is setup and how an interrupt procedure would call other code. Purely because I don't know how to use the ThreadKit - not to question it's functionality. I actually like the idea of the basic threading.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #29 on: October 13, 2011, 09:37:57 am » |
westfw, Almost nothing you say about modern preemptive kernels is true. I know a lot about Cisco's IOS. I worked in the network research group at LBNL and we had a close relationship with Cisco. The head of our department, Van Jacobsen, became chief scientist at Cisco. IOS has a run to completion scheduler, which means that the kernel does not pre-empt a running process — the process must make a kernel call before other processes get a chance to run. For Cisco products that required very high availability, such as the Cisco CRS-1, these limitations were not acceptable. In addition, competitive router operating systems that emerged 10–20 years after IOS, such as Juniper's JUNOS, were designed not to have these limitations. Cisco's response was to develop a new version of Cisco IOS called IOS XR. It is based on 3rd party real-time operating system micro-kernel (QNX), and a large part of the current IOS code was re-written to take advantage of the features offered by the new kernel — a massive undertaking. A company like Cisco can afford to spend a lot of resources to polish a product that will sell in large volume and high profit. The methods used by Cisco for communications don't necessarily translate to other applications. For one-off hobby projects a RTOS can be a good tool to accomplish more with less code and time. I agree that a ATmega 328 is small for use of an OS and it wasn't designed for quick context switches. Still FreeRTOS can do a context switch on a m328 in about 50 us. ARM processors were designed to be run with a micro-kernel. A modern micro-kernel can do a context switch in as little as 2.2 us on a 72 MHz stm32 http://yagarto.de/projects/rtoscomp/index.html. ARM Arduino is where a RTOS could help hobbyists accomplish more sophisticated projects. Here is the FreeRTOS test program I used with a scope to check the context switch time. The lower priority task switches an LED on, off, on, and then gives a semaphore to do a context switch to a higher priority task which turns the LED off. #include <AvrFreeRTOS.h>
#define LED_PIN 3
xSemaphoreHandle xSemaphore; static void ledOffTask(void *pvParameters) { for (;;) { xSemaphoreTake(xSemaphore, portMAX_DELAY); digitalWrite(LED_PIN, LOW); } }
static void ledControl(void *pvParameters) { for (;;) { vTaskDelay(10); digitalWrite(LED_PIN, HIGH); digitalWrite(LED_PIN, LOW); digitalWrite(LED_PIN, HIGH); xSemaphoreGive(xSemaphore); } }
void setup() { pinMode(LED_PIN, OUTPUT);
xTaskCreate(ledOffTask, (signed portCHAR *)"Task1", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY + 2, NULL);
xTaskCreate(ledControl, (signed portCHAR *)"Task2", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY + 1, NULL);
vSemaphoreCreateBinary(xSemaphore); vTaskStartScheduler(); }
Logged
