Topic: Serial read to a string (Read 593 times) previous topic - next topic
N314
Im trying to send a word to my arduino perform an action based on that word.
is there any way I can use "Serial.read()" into a string?
dc42
Not directly. Personally, I'd avoid using String because of the variable memory usage and memory fragmentation that it causes. Since you know what words you are expecting, you can use a fixed length buffer to read the serial data into, taking care not to let the buffer overflow if you receive unrecognised data.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
zoomkat
Simple code to capture characters sent from the serial monitor into a string.
Code: [Select]
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
  Serial.println("serial test 0021"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);  //delay to allow byte to arrive in input buffer
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
