Topic: 3d printer [need advice] (Read 7270 times) previous topic - next topic
Soranne
Oct 08, 2011, 09:14 pm Last Edit: Oct 08, 2011, 09:15 pm by Soranne Reason: 1
Hi everyone!
I was thinking of making a 3d printer controlled by Arduino, but I don't think I'll manage to build it as I don't have the right tools.
So I was thiinking of buying a kit with no electronic (only motors and mechanic parts) but I only found really expensive kits such as the makerbot one or RepRap.
I find it really expensive for a few pieces of plastic...
Do you know any kit for less than 130$ with no electronic or less than 200$ with electronic?
Thanks to you all!
My projects :
- Interfacing with Minitel : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1271350467
- Arduino PIC programmer : http://ardu
Grumpy_Mike
Quote
The problem is those RepRap parts take a couple of hours to print.
Have you seen these:-
http://www.emakershop.com/browse/printed-parts
The other parts are just threading an nuts and bolts.
The stepping motors are the most expensive part and they will be needed what ever system you get.
Also look at the repstrap builds on the reprap website.
Soranne
#2
Oct 09, 2011, 09:33 am Last Edit: Oct 09, 2011, 09:38 am by Soranne Reason: 1
I know stepper motors are the expensive part (with the platic extruder) but I already have some powerful ones for less than 6 euros. Moreover, 500 euros is really to much for a student like me... :s
If I buy these : http://www.emakershop.com/browse/printed-parts for 50£ I will have to buy a plastic extruder which is more than 80£! I can't afford that... :( And I'm not sure of having the right tools to cut threaded rod, or the pieces to connect the motors to the threaded rods...
My projects :
Grumpy_Mike
Quote
Yes you always need an extruder no matter how you get the carriage mechanism.
Quote
A hack saw? Just a few Euros.
Quote
The couplers are included in the plastic parts (Z axis) - the other two axis use belts.
The problem is that to save money you make the parts yourself, but with no tools it is impossible to save money.
As you are a student doesn't you place of education have a workshop equipped with tools you could use if you asked nicely?
Soranne
#4
Oct 09, 2011, 11:13 am Last Edit: Oct 09, 2011, 11:40 am by Soranne Reason: 1
Quote
It's not that cheap, do you know somewhere where i can get one for about 20 euros?
Quote
Do you think I will have enough precision for what is required?
Quote
Does this mean I only have to buy the motors, plastic parts and threaded rods and I have all the mechanic part? Where to get the belts from?
And how to make sure the motors I'll buy will fit with the printer?
In my eduction place i don't have any machines as we're doing maths, physics and chemistry but no engineer work.
Thanks a lot for all your answers!
My projects :
Grumpy_Mike
Quote
Sorry no.
Quote
Yes the saw cuts needed are not very precise, you just need to cut the length to a few mm.
Quote
http://www.mendelfactory.com/index.php?cPath=28
Quote
Look at the size of the hole in the printed part or the shaft size of the recommended motor and make sure your motor is the same size or bigger, then you need to drill it out.
Quote
Every place that has done physics that I have bee to has a small workshop somewhere. Ask around the teachers maybe they know somewhere that you don't know.
Soranne
#6
Oct 09, 2011, 06:05 pm Last Edit: Oct 09, 2011, 06:07 pm by Soranne Reason: 1
Thanks a lot for all your answers! :-)
I'll ask my physic teacher on Thursday to know if there's a workshop at school.
By the way, why are the belts so expensive? It's just a piece of plastic... :-(
My projects :
Grumpy_Mike
Quote
Well it is a toothed belt so there is a bit of structure there. It will also handle a heavy load.
Chagrin
Quote
Timing belts contain a continuous, fiberglass or kevlar reinforcement. If you can imagine how such a thing is molded then you'll probably wonder why they aren't more expensive.
bld
Actually, if you want them properly printed, with enough infill and a low layer height to give a smooth surface, it can take quite a few hours. I printed a set for a friend, at around 100mm/s (with accelration so it varies a lot), and it took me like 10-12 hours of effective printing.
captain-slow.dk | non contagious!
Soranne
#10
Oct 10, 2011, 06:45 pm Last Edit: Oct 10, 2011, 06:48 pm by Soranne Reason: 1
Quote
Quite a lot indeed!
How did you build your own printer?
I was wondering how heavy this object is :
The thing is I'd like to know how much it costs in plastic rope.
@ Grumpy_Mike : I asked my teacher nd he said there were no 3dprinter or cnc at school :-(
My projects :
bld
#11
Oct 10, 2011, 06:46 pm Last Edit: Oct 10, 2011, 06:48 pm by bld Reason: 1
Quote
Quite a lot indeed!
A thing like that would be pretty cheap, would be like 2-300mm of 3mm filament
I think this was around 25 meters
Soranne
Quote
Quite a lot indeed!
Would it be like 0.10€ or more 1€?
My projects :
bld
One spool with 320 meters of 3mm PLA filament is between 60 and 70 euro, and ABS is something around 10 euro cheaper than that.
Soranne
Ok so it would be more than 5€ for this :
, quite expensive...
Is there a way to build our own filament out of plastic bottles for example?
My projects :
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
