Topic: Ubuntu 11.04 64bit error opening serial port (Read 1 time) previous topic - next topic
Mastino
Hello everybody,
Since a couple of days ago I can't upload my codes to arduino. On my Ubuntu OS. Comes this message: http://i56.tinypic.com/x4hcb6.jpg
Before it worked perfectly. I have also win7 64bit on the same pc, in win7 Arduino Ide works well, but not in ubuntu. Maybe somebody has a solution for this problem?
Thanks!
SurferTim
Go to your /dev/ directory and see if you have a "ttyACM0" file. If not, try rebooting the computer with the Ardunino connected. Check again.
Watch for me on National Geographic Wild "When Sharks Attack: Gulf Coast Killers". Airs on June 22nd.
Mastino
Thanks for your replay! Yes I have the "ttyACM0" file in /dev/ directory. And I have restarted the computer with connected Arduino. But it still doesn't work.
SurferTim
Try pressing the reset button on the Arduino, and release it just as the IDE says it is finished compiling and about to start the upload to the Arduino. The timing is a bit tricky sometimes.
At one point, I had to use a Windows version IDE to upload the "blink" example to get rid of the malfunctioning code in the Arduino.
Mastino
No chance..:( I have tried before to upload the blink code to arduino from win7 it was ok. And than I have I have tried to repeat the operation in ubuntu, but the same problem comes again.. One more interesting thing: When Arduino is connected to computer and running code  for example servo back and forth all over the time. And when I start the Arduino IDE in ubuntu the arduino uno stops working for a second. You know the same if you start Serial Monitor the program of arduino uno will reset. So here it happens every time when I start Arduino Ide, or I open I new window. Before it wasn`t so. It seems I must go back to windows:) I think it is something with ubuntu updates..
SurferTim
#5
Oct 09, 2011, 02:05 pm Last Edit: Oct 09, 2011, 02:33 pm by SurferTim Reason: 1
Then it may be a bug in that version. Linux has its share of them.
Take a look at this thread. Each version has its own bugs. This user had a version that the delay() function failed. My repository version would not compile "Serial.begin(9600);". After the upgrade, all is great. Reply #5 covers the bug and fix.
http://arduino.cc/forum/index.php/topic,71182.0.html
These are the "signature errors" for these avr-libc versions:
1.6.8 - Serial.begin(9600) causes a crash.
1.7.0 - delay(1000) causes a crash.
1.7.1 - compiler "no declaration for fabs and ceil" error (prior to editing delay.h as described in the thread link above).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
