Loading...
Pages: 1 ... 4 5 [6]   Go Down
Author Topic: Sticky - Blink Two LEDs, independent, no delay  (Read 3253 times)
0
Offline Offline
Sr. Member
MEGA_Stick_II is here
View Profile
This might be a better solution smiley-wink (at least for more complicated issues)
http://www.element14.com/community/message/40256#40256/l/event-driven-state-machine-framework-for-arduino
« Last Edit: November 21, 2011, 01:06:17 pm by Jassper » Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
 In changing the title and in writing the explanation keep in mind that the most important concept here is the fact that the code is implementing a 'delay' without using the 'delay()' function.  The fact that one or more LEDs are blinking is not really what this is all about.
The blinking of an LED is an example of what can be done with any kind of delay technique.  The blinking of an LED while also doing something else is an example of what can be done when the use of delay() is eliminated, as is the independent blinking of two LEDs.
It also helps introduce how to handle/work with asynchronous events which to my mind is the crux of loop().
Logged
Examples can be found at Learning in the Main Site and at the Playground
Copenhagen, Denmark
Offline Offline
God Member
Have you testrun your PDE file today?
View Profile
In my mind the reason for this "sticky" was to extend the Blink without delay() tutorial to two LEDs. Thus the explanation of avoiding using delay() is assumed covered. This was to help make the mental leap from the single LED to the general case. (Some people cant even make the leap from a LED to a motor ...)
No, it is not a complete example on the "best" way to blink a LED. No, it wasnt an example on how to implement polled multithread programming.
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Quote
Just make sure that if the word 'delay' is used in the title that it includes the parentheses.  Actually it would probably be better to indicate what is being used rather than what is not being used.  How about 'Blink Two LEDs independently without blocking' or 'Blink Two LEDs independently using millis()' ?
Don
Logged
Pages: 1 ... 4 5 [6]   Go Up
Print
Jump to:
