Topic: Interfacing Logitech Gamepad with Arduino using USB Host Shield (Read 2547 times) previous topic - next topic
Parin
Hi to all Arduino developers!
I am trying to interface Logitech Dual Action Gamepad http://www.logitech.com/gaming/controllers/devices/288 with Arduino using oleg's USB Host Shield 2.0. This host shield works with two version of code library.
1. Legacy Host Library https://github.com/felis/USB_Host_Shield
2. Host Library 2.0 https://github.com/felis/USB_Host_Shield_2.0
Library 2.0 supports USB Hub too. I want to Interface Gampad and other USB device (mostly USB touchscreen monitor) so I need Hub functionality working.
I started reading this http://www.circuitsathome.com/communicating-arduino-with-hid-devices-part-1 article about how to read HID reports from Gamepad with Legacy Host Library .(Article is about USB mouce but Gamepad is almost the same). I test the programs on that article with Gamepad and it worked fine. But now I want to develop same sort of program with USB Hub and Library 2.0. and I have some confusion.
I am trying to write similar function to this one for Gamepad
Code: [Select]
void mouse1_init( void )
byte rcode = 0;  //return code
byte tmpdata;
byte* byte_ptr = &tmpdata;
  ep_record[ 0 ] = *( Usb.getDevTableEntry( 0,0 ));  //copy endpoint 0 parameters
  ep_record[ 1 ].MaxPktSize = EP_MAXPKTSIZE;
  ep_record[ 1 ].sndToggle = bmSNDTOG0;
  ep_record[ 1 ].rcvToggle = bmRCVTOG0;
  Usb.setDevTableEntry( 1, ep_record );              //plug kbd.endpoint parameters to devtable
  /* Configure device */
  rcode = Usb.setConf( DEVADDR, 0, CONFVALUE );
  if( rcode ) {
    Serial.print("Error configuring mouse. Return code : ");
    Serial.println( rcode, HEX );
    while(1);  //stop
  }//if( rcode...
  rcode = Usb.getIdle( DEVADDR, 0, 0, 0, (char *)byte_ptr );
  if( rcode ) {
    Serial.print("Get Idle error. Return code : ");
    while(1);  //stop
  Serial.print("Idle Rate: ");
  Serial.print(( tmpdata * 4 ), DEC );        //rate is returned in multiples of 4ms
  Serial.println(" ms");
  tmpdata = 0;
  rcode = Usb.setIdle( DEVADDR, 0, 0, 0, tmpdata );
  if( rcode ) {
    Serial.print("Set Idle error. Return code : ");
    while(1);  //stop
  Usb.setUsbTaskState( USB_STATE_RUNNING );
  return;
1. With new Library do I need to initialize the gamepad this way?
2. New library does not have get/setDevTableEntry. Is it same as get/setEpInfoEntry?
3. getIdle/setIdle are not in new Library but that should be ok i think.
So how does the initialization process go for HID devices with new library. I have attached output of Hub test program and HID report descriptor of Gamepad.
I would appreciate your help and many thanks!
Parin
