Topic: Xbee with Arduino (Read 698 times) previous topic - next topic
simran
I am using xbees with arduino they are communicating through X-CTU but i am not able to figure out how to do the same through arduino programming.
Have to run a mic and a motor wirelessly, it will be really helpful if someone could suggest some tutorial.
PaulS
Quote
Which XBees? How are they communicating through X-CTU? Specifically, how are you validating that two XBees are sending/receiving data.
Are you using shields? Which ones?
Quote
The XBees replace wires. They have absolutely nothing to do with what data you send between the two Arduinos or what those Arduinos do with that data.
simran
I am using Xbee series 2 with Arduino Xbee shield v1.1
On the X-CTU window when we type the data is transmitted and received, to upload the code and make it work is what is needed.
PaulS
Quote
What problems are you having? Are you trying to upload the code using the XBees?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
