Topic: #define versus const and other software performance issues (Read 8563 times) previous topic - next topic
Coding Badly
Actually, I believe there is no add-immediate instruction.  Yup.  There is an add-immediate-word but no add-immediate-byte.
When Atmel says the AVR processor is "RISC", they aren't kidding!
nickgammon
Well I suppose they don't need it, and subtracting is arguably more useful than adding.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
PaulS
Quote
If you're working with integers, you can also do bit shifting to divide by 10. If you do something weird like this, make sure you comment what you did.
Please explain how. Bit shifting one place divides by 2. Then, you still need to divide by 5. I can't figure how how to shift any direction to divide by 5.
nickgammon
A bit of Googling and I found an answer for at least an approximation. And hey, isn't most stuff an approximation? This test sketch:
Code: [Select]
const boolean SHOW_RESULTS = false;
const unsigned long ITERATIONS = 50000;
void setup ()
  Serial.begin (115200);
  Serial.println ();
  unsigned long start;
  Serial.println ("By shifting:");
  start = millis ();
  for (unsigned long n = 0; n < ITERATIONS; n++)
    volatile unsigned long n2, n4, n32, n64, n102, ans;
    n2 = n     << 1;    // n * 2
    n4 = n2    << 1;    // n * 4
    n32 = n4   << 3;    // n * 32
    n64 = n32  << 1;    // n * 64
    n102 = n64 + n32 + n4 + n2;  // n * 102
    ans = n102 >> 10;  // n * 102 / 1024
    if (SHOW_RESULTS)
      Serial.print ("n = ");
      Serial.print (n, DEC);
      Serial.print (" n / 10 = ");
      Serial.println (ans, DEC);
  } // end for loop
  Serial.print ("time taken = ");
  Serial.println (millis () - start, DEC);
  Serial.println ("By multiplying and then shifting:");
  start = millis ();
    volatile unsigned long ans;
    ans = (n * 102) >> 10;  // n * 102 / 1024
    if (SHOW_RESULTS)
  } // end for loop
  Serial.println ("By dividing:");
  start = millis ();
    ans = n / 10;
    if (SHOW_RESULTS)
  } // end for loop
} // end setup
void loop() {}
As written, I get this:
Code: [Select]
By shifting:
time taken = 771
time taken = 294
By dividing:
time taken = 1956
So, the basic method is to multiply by 102 and then shift right 10 bits (ie. divide by 1024). This is an approximation in the sense that we want to multiply by 0.1 but are actually multiplying by 102/1024 (0.09961).
I tried three ways, the first was to multiply by 102 by doing assorted shifts, the second was to let the compiler do the multiplication, and the third to let the compiler do the division.
The figures show that the division was the slowest (1956 mS), my shifting idea second slowest (771 mS) and the multiply-then-shift fastest (294 mS). In fact the multiply-then-shift is over 6 times as fast, if you can stand the loss of precision.
Obviously this is only really useful if you know the numbers in advance. It's also interesting that my attempt to second-guess the compiler and do a "more efficient" multiply by 102 was actually quite a lot slower than what the compiler generated, left to its own devices.
More info:
stimmer
Your method would be faster if you hadn't made the intermediates n2, n4, n32, n64 and n102 unnecessarily volatile. You could make it slightly faster still with the chain 2,3,6,96,102.
The reason the multiply method is fastest is because the ATmega has a 2 cycle 8-bit multiply instruction built in. You really want the shift to be 8 or 16 bits as then the shifting can be done for free (the compiler just moves the bytes in the long down by 1 or 2 places). Try (n*6554)>>16
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
nickgammon
Quote
You are right. I had volatile there to convince the compiler to do the work at all, but making only ans volatile gave me this:
Code: [Select]
By shifting:
time taken = 497
time taken = 294
By dividing:
time taken = 1956
Quote
Try (n*6554)>>16
Good call. I got:
Code: [Select]
time taken = 75
Closer too. Rather than multiplying by 0.1 we are multiplying by 0.1000061.
More info:
Coding Badly
Which is about the same number of significant digits expected from float.  Orders of magnitude faster and just as accurate.  What's not to like!
robtillaart
wrote a shift multiply finder few years back in C# - http://www.codeproject.com/KB/cs/FindMulShift.aspx -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
