0
Offline
Newbie
Arduino rocks
« on: June 27, 2009, 03:23:32 am » |
/* Measuring temperature with Arduino
Alan Wendt, PhD A thermistor is a resistor whose resistance decreases as the temperature increases. With some care, you can use Arduino to read accurate temperatures. My project is a decent evaporative cooler controller. In Arizona, you can usually run the fan motor on high or low, and you can also turn the water on and off. If you measure the temperature in the house, outside in the shade, and the air right after the evaporative pads, you can calculate the relative humidity, and also program the unit to shut down the pump if the outside air is already cool enough.
To measure the current resistance of the thermistor, wire a thermistor and a 10K resistor up in serial. Connect the open end of the thermistor to +5V, and the open end of the resistor to ground. Now, there's a 5V drop across the pair, and the drop across the thermistor is proportional to its resistance as a fraction of the sum of both resistances. For example, if the voltage at the junction of resistor and thermistor is 4, that means that the thermistor dropped 1 volt, and the fixed resistor dropped 4, so the thermistor's current resistance is 1/4th of the fixed.
Once you have the resistance, the temperature of the thermistor is approximated with the formula:
T = 1 / (A + B log(R) + C log(R) ^ 3)
where A, B, and C are experimentally-determined constants. (The Steinhart-Hart approximation). You need to collect 4-5 few data points, preferably with a big temperature spread.
I put the board into a refrigerator along with a little Radio Shack remote thermometer sensor, and snaked out the USB cable and the remote sensor cable. Once the program's downloaded, enter the "serial monitor" in the Arduino SDK to see the output.
Google "steinhart hart moshier" for further discussion of calibration, and for software to calculate the constants.
int firstSensor = 5; // first analog sensor
void setup() { // start serial port at 9600 bps: Serial.begin(9600); }
void loop() { // read the analog input float a5 = analogRead(5); Serial.print("analogread = "); Serial.print(a5); Serial.print("\n");
// calculate voltage float voltage = a5 / 1024 * 5.0; Serial.print("voltage = "); Serial.print(voltage); Serial.print("\n");
// calculate resistance float resistance = (10000 * voltage) / (5.0 - voltage); Serial.print("resistance = "); Serial.print(resistance); Serial.print("\n");
// calcuate temperature. Use these values for A, B, and C till you // get everything working, and then do some measurements to calibrate // your thermistor in circuit. float logcubed = log(resistance); logcubed = logcubed * logcubed * logcubed; float kelvin = 1.0 / (-7.5e-4 + 6.23e-4 * log(resistance) - 1.73e-6 * (logcubed));
// Convert to Fahrenheit float f = (kelvin - 273.15) * 9.0/5.0 + 32.0; Serial.print("temp = "); Serial.print(f); Serial.print("\n");
// delay 1s to let the ADC recover: delay(1000); }
