Topic: communication with processing messed up (Read 3326 times) previous topic - next topic
clankill3r
I just want to send a delay value with arduino but i thought let's start with sending the frameCount of the processing sketch.
arduino:
Code: [Select]
    #define LED 13
    int incoming;
      pinMode(LED, OUTPUT);
      if (Serial.available()) {
        incoming = Serial.read();
        Serial.println(incoming);
Processing:
Code: [Select]
    import processing.serial.*;
    Serial port;
     println(Serial.list());
     port = new Serial(this, Serial.list()[1], 9600);
    void draw() {
      port.write(frameCount);
This is the output i get in the Serial monitor from arduino (exept the last line):
Apart from it being messed up, also a lot of frames are not coming in...
Quote
    123
    5
    7
    8
    1112
    3
    15
    18
    2122
    3
    2526
    7
    29
    31
    32
    3536
    7
PaulS
How many times do you suppose the draw() method in the Processing application is called, while the Arduino reads the serial data that it got? draw() is sending data far faster than the Arduino can read it, so the Arduino's receive buffer fills up. Data that arrives while the buffer is full is placed in the bit bucket. There is no method to retrieve data from the bit bucket.
Your Processing application has not implemented a handler (serialEvent) to be called when serial data arrives, so that data is not processed. Not processing data is far faster than processing it.
The speed at which draw() is called is only marginally affected by serial data processing. You need to add a delay to draw, so that data is sent at a more manageable (by the Arduino) rate.
clankill3r
I tried with a delay of 1000 in processing but this didn't help.
Also a frameRate(1); didn't help, still bad output (only slower).
Now i tried the followong code, arduino serial monitor has output like this:
Quote
9
69
9989999999
10
19
299
1399499959199
7899999999
2099299
299
329
599
And processing is printing null all the times.
Code: [Select]
#define LED 13
int incoming;
    String out = incoming;
    out += 9999;
    Serial.println(out);
Code: [Select]
Serial port;
String inString;
int lf = 9999;
  frameRate(1);
port.bufferUntil(lf);
void draw() {
  println(inString);
void serialEvent(Serial port) {
  inString = port.readString();
p.s. the function delay will be removed in next processing
PaulS
Quote
out += 9999;
You are adding a String and a number. Is that really what you want to do?
Processing can be told to buffer until the carriage return/line feed that the Arduino can send, using Serial.println().
Processing is not putting any separator between the strings that it sends. So, the Arduino has no way of knowing where a number begins and ends.
ItwouldbelikeyoutryingtoreadasentenceItypedwithnospacesbetweenthewords.
Quote
I don't see one there, now.
You can do without the delay, if you have Processing send only when the Arduino says that it is ready.
clankill3r
Alright, here the line feed is a new line, but this also doesn't work...
Quote
    Serial.println(9999);
PaulS
Code: [Select]
Storing the one character read into a String object is a waste of resources.
What is the 9999 being sent for?
For every character read, the Arduino sends 9 back out...
Quote
What a shame.
If you described what did actually happen, you might get help instead of just (fake) sympathy.
clankill3r
the 9999 was sent for the bufferUntil, i had a high int so it would be higher then the delay i want to send later.
Now i use the char 'h'
Quote
how's that?
Arduino:
Code: [Select]
#define LED 13
int incoming;
    Serial.println(Serial.read());
    Serial.println('h');
processing:
Code: [Select]
Serial port;
String inString;
char lf = 'h';
  frameRate(1);
void draw() {
  println(inString);
processing output is like:
Quote
h
h
h
5
h
5
h
h
8
h
8
h
90
h
90
h
90
h
1
2
h
h
1
h
6
h
6
h
1h
and arduino output is like:
Quote
1
h
2
3
h
4
6
h7
h
1
1h1h13
14
5
1
7
h
18
19
h
PaulS
Quote
how's that?
Code: [Select]
The first line reads one character.
The 3rd line prints that character plus a carriage return and line feed. 3 characters.
The 4th line prints '9', '9', '9', '9' and a carriage return and line feed. 6 characters.
6 + 3 = 9.
Code: [Select]
Now, you are sending the character plus a carriage return and line feed, the 'h' plus a carriage return and line feed, for a total of 6 characters.
Perhaps the Serial.println()s should be Serial.print()s to get rid of the carriage returns and line feeds.
I don't know what frameCount is, or how or where it is initialized or incremented. So, I can't comment on the output you show.
How are you capturing the Arduino output separate from the Processing output? You have one serial connection. Either the Serial Monitor should be on the other end (the Arduino is on one end) OR the Processing application should be on the other end.
What OS are you using?
What, exactly, is the problem we are trying to address?
clankill3r
Then the bufferUntil is useless right?
http://processing.org/reference/libraries/serial/Serial_bufferUntil_.html
Quote
A carriage return is like pressing enter/return on the keyboard right? So isn't that a line feed allready?
frameCount prints the current frame number, so when you start a processing sketch it starts with 1 and then it just counts.
It would be like this in arduino (only in processing it's a default thing, you don't have to create the variable frameCount)
Code: [Select]
int loopCount = 0;
    loopCount++;
Quote
The processing pde has a console, if i use println("something"); then it goes to the processing console, i could also create a printWriter to create a textfile for example then i can use output.println("something"); for example and it gets added to the textfile.
Quote
mac os x, lion
Quote
I want to set a simple delay with processing. Setting a delay between 0 and 255 is quite easy for that just send a byte, however i need a bigger range. I think something between 0 and 1000ms. Afcorse i could use a byte and multiply it by 4 by the arduino which is more easy (but 4 times less precise) but for the purpose of learning i don't.
So at the moment i just try to send a value with processing, receive it with arduino and then send it back to processing (<< that is my goal).
I used frameCount for now cause it's easy to see if things are going correct since it's produces 1,2,3,4,5,6,7,8,9,10,11 etc. If you look in the output below, you see a bit of it coming back.
PaulS
Quote
Not at all.
Quote
Ever seen a typewriter? There is a lever that you use to return the carriage to the left side of the typewriter, and advance the paper so you can type on the next line. So, the carriage return and line feed are separate activities. The enter key on a PC emulates the carriage return/line feed. How do you suppose it does that? Hint: it was two separate activities.
Quote
"it just counts" when? Details are crucial. What causes it to increment?
Quote
That explains how you know what Processing received. You seem to know what the Arduino sent, too. How?
Quote
Afcorse.
Quote
Then why complicate with that 9999 or h crap. Just use the Serial.println() function on the Arduino and bufferUntil('\n'); in the Processing application.
The Processing application sends a string ("0", "1", ... , "10", "11"). You need to read that string, convert it to a number, and send that number back to Processing (as a string) to validate the communication process.
clankill3r
Quote
I understand it with a typewriter, but not with arduino.
Quote
Quote
from: http://processing.org/reference/frameCount.html
Quote
The system variable frameCount contains the number of frames displayed since the program started. Inside setup() the value is 0 and and after the first iteration of draw it is 1, etc.
So every iteration of draw increments it.
Quote
Quote
by the serial monitor, or don't you mean that?
Quote
Quote
bufferUntil('\n'); is a good idea! thanks! wish i could test it right away.
PaulS
Quote
OK. Facts are good.
Quote
The Serial.println() function outputs the data specified followed by a carriage return and a line feed. They are separate ASCII characters (10 and 13).
Quote
On Windows, you can have the Serial Monitor communicating with the Arduino, OR Processing communicating with the Arduino, but not both. I have no idea what that isn't the same on other OSs.
clankill3r
is a carriage return there so it knows that the output of the data specified is complete?
And if so, wouldn't it then outputs the data specified followed by a line feed and the the carriage return? (instand of carriage return and then line feed).
cause
Serial.print("something\n");
produces the same as
Serial.println("something");
PaulS
Quote
cause
Your proof?
clankill3r
no i assume, in processing those results will be the same:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
