Topic: getting Ethernet WebClient to Constantly Pulling Data (Read 1 time) previous topic - next topic
wwrgsww
So I am building a larger network of Arduino Uno's / Network Shields.  About 20 of them will constantly query a server I have (about every 1.5 seconds).
The server simply will output a small amount of data.  either "0:" or "1:m:s"  (where m = Minutes | s = seconds) and it will parse that data for minutes and seconds.
I can get the arduino to connect to the server and pull the data once during the loop with this code.
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,0,177 };
byte server[] = { 192,168,0,98};
Client client(server, 80);
  // start the Ethernet connection:
  Ethernet.begin(mac, ip);
  // start the serial library:
  Serial.println("t:");
  // give the Ethernet shield a second to initialize:
client.println("GET /client.php");
    client.println();
    char c = client.read();
    Serial.print(c);
So they are not pulling a lot of data, but the issue is it only runs once,  I need it to loop.  keep querying that server over and over
wwrgsww
Updated code
Code: [Select]
#include <SPI.h>
int mytime = 0;
  while (mytime == 0){
    //Ethernet.begin(mac, ip);
    client.println();
    Serial.print(c);
    delay(2000);
  }//While
That gets me this
Code: [Select]
t:
t:
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
draythomp
I see a couple of problems initially.  You need to do some checking to see if you got the connection, wait for the connection, wait for the response, etc.  Take a look at the various tutorials out there and start from there.  The code at http://arduino.cc/en/Reference/ClientConnected should be enough to get you started.  The idea is to get a single working connection, then start looping on it.
Trying to keep my house under control http://www.desert-home.com/
zoomkat
You may have several problems. Sounds like you may have overlapping request to the server.The w5100 based ethernet shield is only setup for four connections, and your code apparently has nothing to close the current connection when the data is received. Below is some simple client test code for reference.
Code: [Select]
//zoomkat 11-13-10
//simple ethernet client test code
//for use with IDE 0021 and W5100 ethernet shield
//modify the arduino lan ip address as needed
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // Arduino IP address
byte server[] = { 208, 104, 2, 86 }; // zoomkat's web site
  Serial.println("starting simple arduino client test");
  Serial.println("connecting...");
  if (client.connect()) {
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
    Serial.println("connection failed");
  if (client.available()) {
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    Serial.println("==================================");
    Serial.println("");
    client.stop();
    for(;;); //stops loop for a single get request.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
wwrgsww
My Code was so horrible.
I had one of my co-workers who is amazing at C look at it.   he took care of everything,  once this project is done, Ill post plenty of pictures / code.
draythomp
The problem with that solution is that you still don't know how to do it.
zoomkat
Quote
Some what of a lame assumption. One can easily learn from code that works as opposed to trying to learn from broken code.
wwrgsww
While this is true,  I learned PHP by my self looking at other peoples code.       I understand basic parts of C however the way he did it, using arrays It would of taken me a while to figure that out.
I think this overall project that we are working on, with 20+ Connected Arduino's will be pretty cool.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
