Loading...
Pages: [1]   Go Down
Author Topic: fade led using IR remote  (Read 541 times)
Offline Offline
Newbie
View Profile
Hi
i want to make a simple application: turn on/off a fading led using IR remote. I am using IRremote library (http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html
And my code just doesnt work.. It turns on when i first press the button, but doesnt react on next signals. Just dont know what to do..
here is the main part
Code:
  if (irrecv.decode(&results))
  if (results.value==52160) {  //it is the value remote button i use
    if(sw==1) sw=0;
    else sw=1;
     irrecv.resume();
 if(sw==1) fade();  //fade led
if(sw==0) zero();  // turn led off
Logged
Scotland
Offline Offline
Newbie
View Profile
Hey, check and see if your codes are "multicode" or not,  if so then the first press and second press will send alternate codes!
Logged
New Jersey
Online Online
Edison Member
View Profile
Probably best if you post all your code. That said, consider putting some serial.prints in there so you can see what it is doing.
Logged
Offline Offline
Newbie
View Profile
Okay, actually the task is a little more complicated, i want ot turn on/off RGB lamp which is changing colours in random sequence
when i press "on" button it starts changing colours, but doesn't turn off when i press the button again
Code:
#include <IRremote.h>
#include <Metro.h>
const int irReceivePin =2;
Metro ledMetro = Metro(10) ;
Metro irmetro = Metro(500);
IRrecv irrecv(irReceivePin);
decode_results results;
int prevKey, prevKey2;
float RGB1[3];
float RGB2[3];
float INC[3];
int sw;
int fadeAmount = 5;
 int brightness = 0;
int red, green, blue;
int RedPin = 3;
int GreenPin = 5;
int BluePin = 6;
{  Serial.begin(9600);
  pinMode(irReceivePin, INPUT);
  irrecv.enableIRIn();
        randomSeed(analogRead(0));
        RGB1[0] = 0;
        RGB1[1] = 0;
        RGB1[2] = 0;
        RGB2[0] = random(256);
        RGB2[1] = random(256);
        RGB2[2] = random(256);
   if(sw==1) lamp();
if(sw==0) zero();
  {Serial.println(results.value);
    if(sw==1) sw=0;
    else sw=1;
     irrecv.resume();
void lamp() {
        for (int x=0; x<3; x++) {
                INC[x] = (RGB1[x] - RGB2[x]) / 256; }
         for (int x=0; x<256; x++) {
            if (ledMetro.check() == 1) {
                red = int(RGB1[0]);
                green = int(RGB1[1]);
                blue = int(RGB1[2]);
                analogWrite (RedPin, red);
                analogWrite (GreenPin, green);
                analogWrite (BluePin, blue);
                RGB1[0] -= INC[0];
                RGB1[1] -= INC[1];
                RGB1[2] -= INC[2];
label:
                RGB2[x] = random(556)-300;
                RGB2[x] = constrain(RGB2[x], 0, 255);
if(RGB2[0]==0 && RGB2[1]==0 && RGB2[2]==0) goto label;
void zero() {
   analogWrite (RedPin, 0);
                analogWrite (GreenPin, 0);
                analogWrite (BluePin, 0);
Println results: first line is number of ir button, and then always "0", and nothing when i push the button
« Last Edit: October 08, 2011, 04:24:07 am by deniszhur » Logged
Scotland
Offline Offline
Newbie
View Profile
OK I may be wrong here but are you using a digital pin (2) to recieve the IR , also how exactly have you done the hardware, as far as im aware IR codes are HEX data so they must use a serial input, are you revieving using a IR photo diode, if so im sure that the digital in pin will not suffice for this application.
Logged
New Jersey
Online Online
Edison Member
View Profile
Are you able to get better results with the examples/IRrecvDemo sketch? According to the link you provided, you may need to tweak the library to accommodate the protocol for your particular remote device.
Also, I didn't dig through lamp() in any detail, but you can certainly replace that goto with a do while.
Logged
Scotland
Offline Offline
Newbie
View Profile
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1292326335
Logged
Scotland
Offline Offline
Newbie
View Profile
Oops yeah just actually read the link, so yeah its for a digital string, anyway still would use the com prt for serial, anyway check out, http://www.remotecentral.com/ for some actuall raw binarys of the codes!!
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Add a Serial.print() statement to show when lamp() is entered, and when it ends. There are a lot of hidden delays going on there. When lamp() is executing, you are not reading IR data.
Logged
Offline Offline
Newbie
View Profile
Thank you all very much, hope I will find the solution soon
Logged
Offline Offline
Newbie
View Profile
Is it possible to make program read IR data and run a lamp() program simultaneously? I want to be able to turn the fading lamp off when the fading program is running?
What is the trick?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
What is the trick?
Not using delay(). Or timers of the sort you are using.
Logged
Pages: [1]   Go Up
Print
Jump to:
