Topic: Servo gone crazy: moves without me sending command. (Read 5760 times) previous topic - next topic
ldfka
Hello,
I have two of these little servos: http://www.dealextreme.com/p/sg90-mini-servo-with-gears-and-parts-2kg-torque-35764
1- I tested them with the code bellow (from playground). They were working fine connected to an arduino:
2- Now that I almost fish assembling my robot and have them connected to a serial servo controleur, I started programing.
3- All my servos work fine expect for these two. They move like crazy without me sending any command.
4- I thought it might be some kind of incompatibility with the servo controller. But when I plug them back to a stock arduino with same code as before they keep moving continuously in one direction or alternatively.
May I have damaged them somehow? Here is the model of the serial controller I used: http://www.pololu.com/catalog/product/207/resources
Any help would be welcome!
Code: [Select]
#include <Servo.h>
int minPulse1     =  0;   // minimum servo position
int maxPulse1     =  180; // maximum servo position
int turnRate1     =  10;  // servo turn rate increment (larger value, faster rate)
int minPulse2     =  0;  // minimum servo position
int maxPulse2     =  180; // maximum servo position
int turnRate2     =  10;  // servo turn rate increment (larger value, faster rate)
int buttonPin     = 13;    // pin that the trigger will be connected to
/** The Arduino will calculate these values for you **/
int centerServo1;
int centerServo2;
int pulseWidth1;     // servo pulse width
int pulseWidth2;     // servo pulse width
Servo servo1;
Servo servo2;
  pinMode(buttonPin, OUTPUT);
  servo1.attach(4);
  servo2.attach(10);
  centerServo1 = maxPulse1 - ((maxPulse1 - minPulse1)/2);
  centerServo2 = maxPulse2 - ((maxPulse2 - minPulse2)/2);
  pulseWidth1 =  centerServo1;
  pulseWidth2 =  centerServo2;
  Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
  Serial.println(" Arduino Serial Servo Control");
  Serial.println("Press a, s, d, or w to move, spacebar to center, and f to fire");
  // check for serial input
  if (Serial.available() > 0) {
    int data = Serial.read(); // read the incoming byte:
    digitalWrite(buttonPin, LOW);  // turn the pin off on any incoming data
    switch(data)
case 'a' :  pulseWidth1 = pulseWidth1 - turnRate1;  break;
case 'd' :  pulseWidth1 = pulseWidth1 + turnRate1;  break ;
case ' ' :  pulseWidth1 = pulseWidth2 = centerServo1;  break;
case 's' :  pulseWidth2 = pulseWidth2 - turnRate1;  break;
case 'w' :  pulseWidth2 = pulseWidth2 + turnRate1;  break ;
case 'f' :  digitalWrite(buttonPin, HIGH); delay (1000); digitalWrite(buttonPin, LOW); break;
    // stop servo pulse at min and max
    if (pulseWidth1 > maxPulse1) { pulseWidth1 = maxPulse1; }
    if (pulseWidth1 < minPulse1) { pulseWidth1 = minPulse1; }
    if (pulseWidth2 > maxPulse2) { pulseWidth2 = maxPulse2; }
    if (pulseWidth2 < minPulse2) { pulseWidth2 = minPulse2; }
     servo1.write(pulseWidth1);
     servo2.write(pulseWidth2);
    // print pulseWidth back to the Serial Monitor (uncomment to debug)
    Serial.print("Servo 1: ");
    Serial.print(pulseWidth1);
    Serial.print(" Servo 2: ");
    Serial.print(pulseWidth2);
    Serial.println("degrees");
johnwasser
Did you try connecting the 'bad' servos in place of two of the servos that 'work fine'?  If the 'bad' servos work fine when you put them in place of known working servos then either they were connected to bad channels on the controller or the software driving those channels is faulty.  If the servos misbehave with known good channels, the problem is the servos.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
ldfka
Hello, Thanks for your answer,
Yes I did connect the 'bad' servos to the known to work channels: same issue, they move unexpectedly.
I don't know much about servos, but the only reasons I see is that there electronics went bad. Do you know any way to correct that ?
Thanks
Grumpy_Mike
Quote
I love the idea of fish assembling a robot, what sort of fish bass, bream or salmon?
The reason why a servo moves like this is that it's input line is floating. This can be due to not initialising the pins connecting the servo as an output. I see in your code you don't do this, so add those lines and try again.
zoomkat
Simple servo test code that can be used to test individual servos.
Code: [Select]
// zoomkat 10-14-11 serial servo test
// type servo position 0 to 180 in serial monitor
// for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(2000); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  // allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    myservo.writeMicroseconds(readString.toInt()); //convert readString to number for servo
    //myservo.write(readString.toInt()); //for degees 0-180
    readString=""; //empty for next input
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
ldfka
Quote
I meant 'finish', never mind my tuna brain :D
OK will try the code bellow. But though it use to work fine with this code. And I expect the servo controller to initialise the servo correctly.
Could you be more precise about what you mean by 'input line is floating'?
Thanks a lot for your help.
Grumpy_Mike
When a line is an input it is not exerting any voltage pull in any direction. Doing a digitalWrite() on an input pin turns on an off the 30K internal pull up resistor. This is too high an impedance for some of your servos (your bad ones) but it looks like it is just enough for your other servos, but it is not very good.
Quote
You might expect it but no.
For more on floating inputs, see:-
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
johnwasser
Quote
That call to pinMode( pin, OUTPUT) in the Servo library looks like it should initialize the pin correctly:
Code: [Select]
uint8_t Servo::attach(int pin, int min, int max)
  if(this->servoIndex < MAX_SERVOS ) {
    pinMode( pin, OUTPUT) ;                                 // set servo pin to output
    servos[this->servoIndex].Pin.nbr = pin;
    // todo min/max check: abs(min - MIN_PULSE_WIDTH) /4 < 128
    this->min  = (MIN_PULSE_WIDTH - min)/4; //resolution of min/max is 4 uS
    this->max  = (MAX_PULSE_WIDTH - max)/4;
    // initialize the timer if it has not already been initialized
    timer16_Sequence_t timer = SERVO_INDEX_TO_TIMER(servoIndex);
    if(isTimerActive(timer) == false)
      initISR(timer);
    servos[this->servoIndex].Pin.isActive = true;  // this must be set after the check for isTimerActive
  return this->servoIndex ;
ldfka
Quote
Hmm not sure I understood this, to me I'm using an output which send a pulse of X ms to the servo and not an input.
Maybe it would help me if you tell me between which pin of the servo you advise to put a pull up resistor?
Thanks!
Grumpy_Mike
Quote
So initialise the pin as an output, you were not doing that in your code.
AWOL
Looks like  a confusion of pulse widths ( microseconds) and angles.
Have a good read of the sources of the servo library, and get back when you understand the ranges of values involved.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
zoomkat
Servo test code that takes either angle input or microsecond input. In this code pin seven is used for the servo control signal. If this doesn't work, you probably have a power supply problem and/or the external power supply does not have a common ground with the arduino.
Code: [Select]
// zoomkat 10-22-11 serial servo test
// or for writeMicroseconds, use a value like 1500
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
    delay(2);  //slow looping to allow buffer to fill with next character
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
rameses32
I have 4 of those servos, in 2 of the 4 the signal wire had come loose inside the servo,from new, causing it shimmy and shake and turn one direction hard against the stop. if you have a small screw driver and a soldering iron it is an easy 2 minute fix. Hope this helps.
Charley
rameses32
Sorry, it wasn't the signal wire , it was a wire on the little pot inside the servo, i just remembered.
Charley
