Topic: Denon receiver control (Read 1 time) previous topic - next topic
perjarle
Hello all
I am quite new to electronics, but am quite experienced programming with Java.
I own a Denon AVR-2808 Surround receiver.
It has a RS232 interface which I believe can be used for something useful.
The attached pdf describes the available commands and events that can be sent and received over RS232C
It would be fun to make a control interface using Arduino. It could be a webserver interface or a touch screen  :)
I guess I need to make a shield for attaching a serial cable.
This is the pinout described:
Connector type: DB-9pin female type, slave straight connection (DCE type)
( 1pin : GND , 2pin : TxD , 3pin : RxD , 5pin : Common(GND) , 4,6,7,8,9pin : NC )
The communication format is as follows:
Synchronous system : Tone step synchronization
Communication system : A half duplex
Communication speed : 9600bps
Character length : 8 bits
Parity control : None
Start bit : 1 bit
Stop bit : 1 bit
Communication procedure : Non procedural
Communication data length : 135 bytes (maximum)
Can anyone guide me how I can make the RS232C shield and how to setup the communication?
Best regards
Per-Jarle
PaulS
First thing you'll need is a MAX232 chip to convert the TTL levels that the Arduino deals with to the RS232 levels that the receiver deals with.
You can (and should) mock this up on a breadboard first.
MarkT
If you have a computer with a serial connector on it then that is probably the place to start experimenting - rather than building new hardware.  Once you know it can be done then migrate to microcontroller version?
