Topic: Yet Another RGB LED N00b (Read 758 times) previous topic - next topic
rmd6502
Yup, bought a Luxeon RGB from Sparkfun, hooked it to the PWM pins (9,10,11) via a ULN2003, and grabbed one of the many serial RGB sketches available on the web.
Since I wanted to test it with hyperterminal, I made it a bit more human-friendly, at the cost of taking more time and space.  The platform was an ATMega88 without a bootloader (the one I made didn't work, but I think the problem was the baud rate was off due to the CLKDIV8 being set), with a Dragon and an STK500.
Here is my code for your amusement and edification:
/*Serially controlled RGB-LED (originally by Roland Grichnik)
*17.03.2009.  Modified by Robert Diamond 7 Sep 2009
*inspired by the Serial tutorials and some threads on Arduino-Forum
*Thanks to mem and AlphaBeta from the Arduino Forum, which made serial communication another bit (if not a byte...) clearer for me!
byte r_pin = 9;
byte g_pin = 10;
byte b_pin = 11;
// number being constructed
byte n = 0;
// 1 = r, 2 = g, 3 = b
byte m = 0;
byte last_n = 0;
enum colorMode {
 MODE_NONE = 128, MODE_R, MODE_G, MODE_B };
void setColor();
 Serial.begin(19200);
 analogWrite(r_pin, 0);
 analogWrite(g_pin, 0);
 analogWrite(b_pin, 0);
 Serial.write("Ready\n");
 if (Serial.available()) {
   byte s = Serial.read();
   switch(s) {
     case 'R':
   case 'r':
     if (m) setColor();
     m = MODE_R;
     break;
   case 'G':
   case 'g':
     if (m) setColor();
     m = MODE_G;
     break;
   case 'B':
   case 'b':
     if (m) setColor();
     m = MODE_B;
     break;
   case '6':
   case '7':
   case '8':
   case '9':
   case '0':
   case '1':
   case '2':
   case '3':
   case '4':
   case '5':
     m &= 0x7f;
     last_n = n;
     if (n >= (26 - (s > '5'))) n = n % 100;
     n = n * 10 + (s - '0');
     break;
   case 8:
     n = last_n;
     last_n = n / 10;
     break;
   case 10:
   case ' ':
   case ';':
   s = 10;
     setColor();
     break;
   default:
     break;
   Serial.write(s);
void setColor() {
 const char *c = NULL;
 switch(m) {
 case MODE_R-128:
 c="red";
   analogWrite(r_pin, n);
   break;
 case MODE_G-128:
 c="green";
   analogWrite(g_pin, n);
   break;
 case MODE_B-128:
 c="blue";
   analogWrite(b_pin, n);
   break;
 if (c) {
   Serial.write("\nSetting ");
   Serial.write(c);
   Serial.write(" to 0x");
   Serial.println(n, HEX);
 m = MODE_NONE;
 last_n = 0;
 n = 0;
rmd6502
Now that I've posted, I can tell you that Sparkfun's part page is http://www.sparkfun.com/commerce/product_info.php?products_id=8718.
Also, when I do this 'for real' I'll probably use a NSS40601 (Vce(sat) = .2V) or one of the newer FETs with low Rdson, since the ULN drops about 1.2v, so it's eating up to 1.2W, almost half what the LED uses!
