Topic: Using Serial Monitor to select a melody?? (Read 1 time) previous topic - next topic
I am just beggining at arduino so I am having some problems with coding.
I want to make a melody selector for my arduino wich i can select a melody on the serial monitor and play it directly so i dont have to upload a melody each time i wan to try it.
My final project purpose is for arduino to create a melody on its own ( need to create an AI with musical theory and chords progressions) so that the melody is inlfluenced by an analog input.
So for all this i first need to create a "tester". So i can test diferent melodies and rythms just by inputing words on the Serial Monitor.
Think of it as piano keyboard but instead of a note i want it to play a sequence of notes ( frequency, duration).
Can anyone give some advise on the code for this?
The basis for this can be found here:-
Just change the calls inside the case section to calls to your melody in place of turning LEDs on and off.
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
