Topic: Code: VGA RGB Signal (Read 29048 times) previous topic - next topic
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
WilliamK Govinda
Ah, ok, I will try to post a video and some pictures later today. I also will update the code to work with something more usable and handle at least 2 bit color information. It won't look as great as some of the other solutions we find, but at lest this I understand and not much complicated assembly is been used. ;-) Still need to learn a bit of ATmega328 ASM so I could improve things up.
Wk
WilliamK Govinda
I was wondering on doing a "tiles" based display. So it takes much less RAM and still can do some nice things with this. But I need to know ATmega328/168 Assembly, to render the screen at x number of cycles. Any hints on this?
Wk
WilliamK Govinda
And here's the video:
http://www.youtube.com/watch?v=-0v24aTLmR8
WilliamK Govinda
#20
Oct 23, 2011, 07:44 pm Last Edit: Oct 23, 2011, 07:49 pm by WilliamK Reason: 1
Here's a new code, it has only one color, but handles 21x32 tiles on the screen. Each tile is a 7 byte icon stored in flash, so you can have a lot of icons in flash, not RAM. The problem now is that the code needs more optimizations and also if I try to change the memory data for the tiles in real-time, the video goes out of sync. I need to figure out why.
Edit: I also changed the connections, I'm using SPI for the video output now.
Code: [Select]
 For connections, use:
 Pin 9 = HZync (PWM) = VGA Pin 13
 Pin 8 = VSync = VGA Pin 14
 Pin 11 = RGB Video (SPI) = VGA Pins 1, 2 & 3 (or use just one to get a single color)
 Ground the following pins on the VGA connector: 6 and 10
 VSync us
 64    - Sync   = 1024 cycles
 1020  - Blank  = 16320 cycles
 15240 - Lines  = 243840 cycles
 350   - Blank  = 5600 cycles
266784 = cycles total (60 times per second = 60hz)
 HSync us (Lines)
 3.77  - Sync   = 60.32 cycles
 1.89  - Blank  = 30.24 cycles
 25.17 - RGB    = 402.72 cycles
 0.94  - Blank  = 15.04 cycles
 508 Cycles per line
 VSync Start = 2 lines
 Vsync blank = 32 lines
  480 lines
 VSync Blank = 11 lines
 Total of 525 lines
#include <SPI.h>
#include <avr/pgmspace.h>
#include <avr/sleep.h>
volatile unsigned int linecount;
#define vSyncLow PORTB &= ~(1 << 0);
#define vSyncHigh PORTB |= (1 << 0);
uint8_t tileData[34*21]; // 714 bytes
 set_sleep_mode(SLEEP_MODE_IDLE);
 pinMode(11, OUTPUT);
 pinMode(8, OUTPUT); // VZync = VGA Pin 14
 pinMode(9, OUTPUT); // HZync = VGA Pin 13
 digitalWrite(8, LOW);
 digitalWrite(11, LOW);
 SPI.begin();
 SPI.setClockDivider(SPI_CLOCK_DIV2);
 SPI.setDataMode(0x04);
 memset(tileData,1,sizeof(tileData));
 tileData[0] = tileData[3] = 0;
 tileData[9] = tileData[12] = 2;
 tileData[21] = tileData[21*3] = 0;
 tileData[21+7] = tileData[(21+7)*3] = 3;
 // Disable Arduino Timer0 and UART Timer
 TCCR0A = TCCR0B = 0;
 TIMSK0 = 0;
 TCCR1A =  _BV(COM1A1) | _BV(COM1A0) | _BV(WGM11);
 TCCR1B = _BV(WGM12) | _BV(WGM13) | _BV(CS10); // No Prescalar
 ICR1 = 508;
 TIMSK1 = _BV(TOIE1); // Enable timer overflow interrupt
 OCR1A = 60; // HSync Pulse
 sei(); // enable global interrupts
uint8_t y = 0;
uint8_t y2 = 0;
uint8_t temp = 0;
int line21 = 0;
extern PROGMEM prog_uchar charData[];
#define topOffset 39
 if (linecount >= topOffset && line21 < (34*21))
   sleep_mode();
   temp = pgm_read_byte_near(charData + (tileData[0+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[1+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[2+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[3+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[4+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[5+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[6+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[7+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[8+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[9+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[10+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[11+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[12+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[13+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[14+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[15+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[16+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[17+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[18+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[19+line21]*7) + y);
   SPDR = temp; temp = pgm_read_byte_near(charData + (tileData[20+line21]*7) + y);
   SPDR = temp;
   y2++;
   if (y2 == 2)
     y2 = 0;
     y++;
     if (y == 7)
       y = 0; line21 += 21;
 else if (linecount == 0)
   y = y2 = temp = line21 = 0;
ISR(TIMER1_OVF_vect)
 if (linecount == 0) vSyncLow;
 if (linecount == 2) vSyncHigh;
 if (++linecount == 525) linecount = 0;
And the symbols-test:
Code: [Select]
PROGMEM prog_uchar charData[7*4] = {
B11000110,
B11000110,
B11100110,
B11101110,
B00111000,
B00010000,
B00000000,
B00010000,
B01101100,
B11000110,
B11000110,
B01101100,
B00111000,
B00000000,
B11111110,
B11111110,
B11111110,
B11111110,
B00111000,
B00010000,
B00000000,
B00010000,
B01111100,
B11111110,
B11111110,
B01111100,
B00111000,
B00000000};
robtillaart
Quote
no assembly expert, but you can make an assembly dump of C code with objdump.exe  -S
(from another thread)  --   %avr%objdump.exe -S %build%%target%.cpp.o >disassembly.txt
At least a way to learn from your existing code ...
Rob Tillaart
WilliamK Govinda
Oh, good to know, I was wondering about this last month, thanks for pointing it out, specially how to use it, as I had no clue on how.  :smiley-red: Will try to check this tomorrow or later on.
Wk
dwan
Hi William !
I'm eager to try your code on my CRT VGA screen. What next ? a VGA sync lib ?
Code: [Select]
set.vgasync(800,600, 60);
8)
WilliamK Govinda
Ah, if only that would be possible. ;-) Actually, the signal sync could be possible, but not any image. Handling 640x480 is already pushing the Arduino to its limits, really.
Wk
Nabe_RMC
Hi William !
I watched your nice work videos !
Quote
I got instruction set manual from Atmel web site.
And I used inline assembler.
http://www.nongnu.org/avr-libc/user-manual/inline_asm.html
http://www.stanford.edu/class/ee281/projects/aut2002/yingzong-mouse/media/GCCAVRInlAsmCB.pdf
You can download example codes - using inline assembler.
http://homepage3.nifty.com/two_legs/neo/project/Arduino_LCD/proj_Arduino_LCD.htm
http://homepage3.nifty.com/two_legs/neo/project/Arduino/proj_Arduino.htm
I was inspired by waching your work.
So, I will  modify my codes to VGA signal timing.
Nabe
WilliamK Govinda
Oh, that's nice work, I will check those out tomorrow or so, thank you so much!  8)
Wk
Nabe_RMC
#27
Oct 26, 2011, 06:12 pm Last Edit: Oct 26, 2011, 07:12 pm by Nabe_RMC Reason: 1
I tried with Arduino Duemilanove.
64colors 64x64pixel
http://twitvideo.jp/06hhv
Interface - only 6registers and VGA connector
Red-2bit, Green-2bit, Blue-2bit  -> use 2*3 = 6registers
H-sync and V-sync 2registers
like this
http://twitpic.com/763wr8
Next,I will try to display my twitter icon.
Nabe
Nabe_RMC
Quote
I did.
http://twitvideo.jp/06hzk
Next, Text Display
I will busy this week end.
So, I will try it next week.
Nabe
WilliamK Govinda
That looks great! Can you share your code, please? ;-)
Wk
