Topic: Code: VGA RGB Signal (Read 25444 times) previous topic - next topic
Nabe_RMC
I uploaded that code to Google Code.
http://code.google.com/p/arduino-vgaout/downloads/list
The program is not yet complete.
And there are sum bugs.
I am poor in English.
I hope you correct my incorrect coments.
best regards
Nabe
Nabe_RMC
Hi  All,
I drew the schematic and uploaded.
"VGA11_Schematic_20111030.jpg"
Nabe
WilliamK Govinda
That's perfect! Thank you so much! Later this week I will try things up.  8)
Wk
Nabe_RMC
I mistook for Vsync timing.
I read some documents, and understood about Vsync timming.
And I knew the compiler is good.
x%4 or x%8 faster than x%6
4 = 2^2,and 8 = 2^3 so, convert shift command, I think so.
I could refined x- 70pix from x-64pix.
I uploaded tody's version.
"VGA11_20111031.zip"
and movie
http://www.youtube.com/watch?v=RJ-9i7FxG9w
stimmer
Wired it up, works well :D Great job.
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
Nabe_RMC
Quote
Next, Text Display
I tried.
http://twitpic.com/7c4a1p
I am not satisfied with this.
So I will try another way.
Please wait for it.
Let's enjoy with Arduino!
Nabe
Nabe_RMC
Quote
I did.
http://www.youtube.com/watch?v=naHmwvKvQ4A
Is this useful? I don't think so.
But if someone is interested in this, I will make "print" or "put"  routine.
Next,I will try to draw "sine wave".
WilliamK Govinda
Yes, I love it, please, continue, do post this, as it is useful.  8) Thanks again!
Wk
BoH_Havoc
Awesome Project!
Will give it a try once i'm back infront of my arduino :)
On a sidenote: Would i be able to squeeze out a resolution of 800x600 if using a Chipkit Uno32? Didn't look at the code yet, so if there are big parts coded in assembler/direct calls to the atmega328 nevermind the question ;)
Keep up the GREAT work, this is exactly what i was looking for!
Nabe_RMC
Good Timing! I have not known Chipkit Uno32. Today, I was informed about Chipkit Uno32 so I will oreder it.
I didn't use PIC uC but I have used dsPIC before.
http://homepage3.nifty.com/tlgjpn/neo/project/Pico07/proj_Pico07.htm
the PIC uC on Chipkit Uno32 - If fix length op code, so it does not need jitter correction.
and 32bit core ? then it's easy to count over 256.
ATmega328 - 8bit core so, it needs many cycle at 2byte calculation.
So,on Arduino I don't use 2byte operations as possible.
Quote
Currently: 16MHz ATmega328 x- 70pixel
Chipkit Uno32 - 80MHz?
70pixel x 80/16 = 350 It's easy, I think
But 800 - difficult
In first place, there are not enough memory.
256colors at 1pixel  800x600/1024 = 468kB
I'm busy now. because my Electric RC plane was broken. =(
I have to repair it.
Thanks! and Let's enjoy!
Nabe_RMC
#43
Nov 30, 2011, 04:55 pm Last Edit: Nov 30, 2011, 04:58 pm by Nabe_RMC Reason: 1
Quote
I got advice in this forum.
http://arduino.cc/forum/index.php/topic,80320.0.html
So, I could do it.
https://picasaweb.google.com/117534855759200010314/Twitter_Recently#5680814022555495698
https://picasaweb.google.com/117534855759200010314/Twitter_Recently#5680814017598533218
Thanks a lot!
Nabe_RMC
Nabe_RMC
Quote
I did.
http://twitvideo.jp/06y52
That is the last alpha version.
Next, I will refine the code.
And I will write some documents.
Thanks!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
