Pages: 1 [2] 3 4   Go Down
Author Topic: My RGB LED Stairs Illumination video  (Read 8348 times)
Wisconsin
I LOVE THIS STUFF!!!!
Okay.
So i'm also curious, what kind of pressure sensor did you use?  Like, say i stepped on the left side and then the sensor was in the center.  How does the sensor cover the entire step?
Accelerate to 88 miles per hour.
Okay.
100# flexforce pressure sensor.
To ensure that it is activated, I sandwiched the sensor between two 1/16" stainless steel plates.  The pressure sensor has a dab of hot glue on each side of it and the plates have dabs of hot glue between each corner.  This ensures that even if you step on the outer edge of the plate, it will still transfer pressure to the sensor.
In the breadboard setup, I also experimented with:
  • IR LED emitter and IR detector - this was the most complex solution to set up since the emitter has to blink at 38kHz, be aligned with the detector, and require much more power.  It would also be hard to eliminate dog triggering without mounting it high and then it would be hard to make it blend in.
  • IR proximity detector - this brought it down to one package to install but it requires a lot of depth to mount making it hard to blend in.  The range is only about 36" on it but on a staircase, the width is only 30" so technically would work well.
  • PIR sensor - this also would require a lot of depth to mount (~2") although not as much as the IR emitter/detector above.  Blending in issue is still there using this.
  • Ultrasonic sensor - this could be rigged up two ways for versatility.  Either one at the top and bottom shooting across to the other wall or two in the middle of the facing staircase 180° from each other.  The advantage of the middle is that I could do an installation of one box housing both of them and could track people on the staircase as well as where they were on the staircase.  Theoretically, I could have lit the stair they were on a different color.
I decided on the pressure sensor for simplicity.  It was easy to set up and easy to blend in.  If after a period of time I discover these don't work as well as I would like, I still have the hardware to implement one of the options mentioned above.
Wisconsin
Oh that makes sense.
So do you upload a new program each time or do you have like 1 microcontroller with 1 program and then another with a different one and then a main switch with on-off-1-2-3?
or how do you change from light show to light show?
Also did you need a carpet foot to get under the carpet?
I upload a new program each time.  Except when I want to demonstrate it, the program will be the basic light up and light down routines.  I am going to code in a double tap on the pressure sensor to put it in demo mode so I don't have to upload a new program each time.  Holidays will require uploading a new program to use special lighting patterns as well.  But again, if I want to make it totally computer free, I could use a double tap to go into a mode selection menu that will alternate between patterns with tapping of a pressure pad.
Right now, since I'm changing the program fairly frequently, I have a laptop plugged into the board in the closet under the stairs and I log into the laptop from my upstairs office (Remote Desktop) to do the programming.
I have not placed the top pressure plate under the carpet yet.  Downstairs, it is wood flooring and there was already a runner at the base of the stairs so the plate went below the runner.  Upstairs, it is on the carpet and I threw a mat over it.  Once I am confident enough that this solution will work long term, I will put the upstairs pressure plate under the carpet.  I don't know what the 'carpet foot' you mentioned is though.
Boston Suburbs
I am above your silly so-called "Laws", Mister Ohm.
VERY cool.  Just about the only comment I can make is that I'd suggest you may want to think about either LM2679 (which is a 5 amp version of the regulator) or splitting the sourcing between two regulators.  Up under a staircase, out of sight, I'd just prefer to think there's not going to be anything that will get hotter than say, 150F.  Thermal shutdown.. you are in the range of breakdown of some adhesives and such.  You just don't want a concentrated source of heat in a hidden space.. and splitting the power will spread the heat out.  Not sure which regulator you are using, but you shouldn't really be pulling 1.4A from a regulator that has a current rating of 1.5A.  If you aren't seeing it regularly, don't rely on a fan.  Spread that heat out, and running that close to maximum rating on any component isn't going to be a good thing.  You'll definitely shorten the life of the component, save yourself some concern and beef up that regulator circuit.  Regulators are cheaper than dirt, anyway..
I'd think about adding an lcd and a couple of switches in the closet, maybe one of liudr's keypad shields, whatever-- just a simple menu setup.  From there you could even build out code to be able to build sequences within the interface.. but I'm thinking you would more likely just need a scroll-and-select from a list of pre-built sequences, like you have done.
 AWESOME!!
« Last Edit: October 26, 2011, 08:50:41 am by focalist » Logged
When the testing is complete there will be... cake.
I'd suggest you may want to think about either LM2679 (which is a 5 amp version of the regulator) or splitting the sourcing between two regulators.  Up under a staircase, out of sight, I'd just prefer to think there's not going to be anything that will get hotter than say, 150F.  If you aren't seeing it regularly, don't rely on a fan.  Spread that heat out, and running that close to maximum rating on any component isn't going to be a good thing.
Excellent suggestions.  Thanks.  I am also a bit concerned about using the regulator long term.  At this point with the animations I have, the current may reach 1.3A for a few seconds and that is it.  The regulator barely gets warm with the animations I have set up.  But I have ordered some LM1084IT-5.0 from China.  These will allow me to get more headroom and do an easy replacement of the one I have now without a redesign of the PCB i have on there now.  I am going to also look at getting at least one LM2679, LM2676 or LM2670 to play with.  These are more complicated to set up but appear to generate very little heat.
Currently, I'm working on using a pressure pad tapping routine to select different modes.  It is very simple and elegant.
  • Ambient light level has to be high to enable the tap counting (at night, turning on the stair light is adequate)
  • When pressure pad is activated, count subsequent taps for 2 seconds
  • If there are at least 3 taps, flash the lights on the stairs indicating the selection mode has been selected
  • Start cycling through brief visual representations of each animation (about 2 seconds each)
  • After each animation, pause 1 second and check to see if the pressure pad is still pressed.  If it is, go to the next animation.  If it is not, select this animation as the one to use.
I have it all programmed out and it functionally looks great, but it is currently unstable going into and out of the tapping routines multiple times and becomes completely unresponsive.  Trying to figure that out.    If I can't, I'll have to come up with something else.
Boston Suburbs
Is it a bounce issue?  You might try using the debounce library if you aren't already...
No, not a debounce issue.  I'm checking for a change in the pressure sensor reading to be below a certain threshold.  It then monitors for it to go above the threshold to tell it my foot has lifted off before counting again.  The counts are very accurate.  It is in the functions that the system completely stops responding for some, as yet, unknown issue.  Don't know if it is some kind of buffer overflow or too many functions called within other functions.  I've been spitting out serial data to try to figure out when/why it happens but haven't found anything relevant yet.
A big and great work!
Congratulations! A very good start point for many projects!
Thank you!
Wisconsin
I still love this thread, still great job!!
Have you made any changes to this since then?
Thanks.
I have not made any more changes since my last update; however, I am going to be changing out the pressure pads to switch to an infrared beam soon.  The pressure pads work great but over time start to move around and the sensitivity decreases with repeated use.
The transition to IR is going to require a couple of addition circuits to be added but I shouldn't have to redo what I have.  I plan on using a couple of 555 ICs to modulate the IR emitter so the receiver can accurately detect the beam.  The only downside to this is that the IR emitters are power hungry as compared to the pressure sensors with each drawing up to 50mA.  This will result in an additional $0.50/yr of electricity usage.  But I think I can live with that. smiley-wink
Which rgb leds did you use?
Wisconsin
I would like to know as well.
Also, have you made any modifications to this, how is it coming along?  I really like the idea.
That's just what I need to start the same project in my house!
As the others, I really would like to know which rbg leds are used for this; I will put them inside walls (plasterboard).
Very nice work!
The RGB LEDs used are diffused common anode type that I picked up off of eBay.  They have a rated luminous intensity of 8,000mcd at 20mA.
I have not done anything further with the stairs lately.  I have determined that the pressure sensor are not going to work in my setup long term in the way I have them.  I have the pressure sensor centered between 2 stainless plates with a dab of hot glue on either side to focus the pressure on the sensor.  Then I put a dab of hot glue at each corner to hold the plates together.  It works great for a while but then the hot glue starts breaking down with the continuous walking on it.  I've thought of changing from the hot glue to little rubber pads but have decided to use infrared distance sensors instead.
The sensors have a limited range of about 3 feet so going across the stair case will work great.  The pressure sensors use only 2 wires whereas the infrared sensors use 3 wires.  To install these, I have to either hack in these to my existing board or I have to re-create the top board.  For simplicity, I will likely just hack in the sensors to my existing board.
In my design, there are 3 PCBs to control each of the colors for the LED and the top board has the ATMega IC and the positive connectors for all the LEDs.  If I had to redo this all over again, I would spend the extra money to have a single 2 sided board made to allow me to easily plug each LED into its own connector rather than having to plug each leg of the LED into its own board.  This would make it easier to create something that is marketable to others interested in doing the same thing and would have saved me hours of wiring this up in my closet under the stairs.  But once installed, it has worked flawlessly.
Pages: 1 [2] 3 4   Go Up
