Topic: magnetic card reader with lcd (Read 1 time) previous topic - next topic
Jennsn
I'm trying to make magnetic card reader which reads track1 & track2. I'm using this code http://code.google.com/p/magstripelib/ to read tracks, but the problem is that I can only read 1 track. I need to read both tracks. My skills ends here, but I think that I can write that code if somebody can help me with the beginning. I also need lcd to display data from cards, but I think that I can do it myself :) Thanks for help!
PaulS
Quote
The example contains this:
Code: [Select]
  // Initialize the library for reading track 1...
  card.begin(1);
What does your code contain to read track 2?
Jennsn
Quote
Code: [Select]
  card.begin(1);
Oup, sorry. I mean that I can only read track 1 or track 2 at one time. I'm using that example code provided with that library. I need to read track 1 and 2 at same time.
Code: [Select]
* MagStripeReader - Read data from a magnetic stripe card (track 1, 2 or 3).
* Copyright (c) 2010 Carlos Rodrigues <cefrodrigues@gmail.com>
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
#include <MagStripe.h>
// Visual feedback when the card is being read...
static const byte READ_LED = 13;
static const byte ERROR_LED = 12;
MagStripe card;
* Track 3 is the one that can contain the most characters (107).
* We add one more to accomodate the final '\0', as the data is a C string...
static const byte DATA_BUFFER_LEN = 108;
static char data[DATA_BUFFER_LEN];
  pinMode(READ_LED, OUTPUT);
  pinMode(ERROR_LED, OUTPUT);
  // The card data will be sent over serial...
  card.begin(1);
  // Start with the feedback LEDs off...
  digitalWrite(READ_LED, LOW);
  digitalWrite(ERROR_LED, LOW);
  // Don't do anything if there isn't a card present...
  if (!card.available()) {
    return;
  // Show that a card is being read...
  digitalWrite(READ_LED, HIGH);
  // Read the card into the buffer "data" (as a null-terminated string)...
  short chars = card.read(data, DATA_BUFFER_LEN);
  // Show that the card has finished reading...
  // If there was an error reading the card, blink the error LED...
  if (chars < 0) {
    digitalWrite(ERROR_LED, HIGH);
    delay(250);
    return;
  // Send the data to the computer...
  Serial.println(data);
/* EOF - MagStripeReader.pde */
Jennsn
I just examined code bit more, and I see that it uses 2 Interrupt. And arduino UNO has only 2 interruptus, so I need 2 more. I tried to change "MAGSTRIPE_RDT" pin (data pin) to D7 with adding new interrupt using this tutorial: http://www.me.ucsb.edu/~me170c/Code/How_to_Enable_Interrupts_on_ANY_pin.pdf
But it didn't work. I used this code:
Code: [Select]
  PCICR |= (1<<PCIE2);
PCMSK2 |= (1<<PCINT23);
MCUCR = (1<<ISC01) | (1<<ISC00);
And I have edited that interrupt pin on file named: MagStripe.cpp (Old interrupt pin: 0, I tried with pin 5). Please help, I really need to get this work. Thanks.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
