Pages: 1 2 [3]   Go Down
Author Topic: light control unit code problems  (Read 1293 times)
hi thanks for your reply
the reason being the name button c this will be going into a glass house with four sections hence a,b,c,d.
but yes i could see there could be more improvement on that
making sketch smaller:
ok would you quickly knock an example sketch up to show me this compared to what i have done.
thanks for your time and help.
Seattle, WA USA
Seattle, WA USA
#define A_light 13     // Light A on pin 13
#define B_light 12     // Light B on pin 12
#define C_light 11     // Light C on pin 11
#define D_light 10     // Light D on pin 10
becomes
const int lightPins[] = {13, 12, 11, 10};
#define A_light_button  1// Light A button
#define B_light_button  2// Light B button
#define C_light_button  3// Light C button
#define D_light_button  4// Light D button
becomes
const int switchPins[] = {1, 2, 3, 4};
int buttonA = 0;
int buttonB = 0;         // val will be used to store the
int buttonC = 0;         // state of the input pin
int buttonD = 0;
becomes
int states[4];
  pinMode(A_light, OUTPUT);
  pinMode(B_light, OUTPUT);       //Setting the digital
  pinMode(C_light, OUTPUT);       // pin's as output
  pinMode(D_light, OUTPUT);
  pinMode(time_button, INPUT);
  pinMode(A_light_button, INPUT);
  pinMode(B_light_button, INPUT);
  pinMode(C_light_button, INPUT); // Setting as an input
  pinMode(D_light_button, INPUT);
becomes
  for(byte b=0; b<4; b++)
    pinMode(switchPins[i], INPUT);
    pinMode(lightPins[i], OUTPUT);
Now, you try making the changes to loop(). Read the states in a loop. Create a function to use the state of one pin to toggle the LED on another pin. The function will look like:
void toggleWithLongDelay(int switchState, int lightPin, bool longDelay)
   // Do stuff here...
The call will look like
   toggleWithLongDelay(state[i], lightPins[i], timeButton == HIGH);
That call will be made in a loop, obviously.
UK
Online Online
Don't use 'b' as a loop variable and 'i' as an index
Seattle, WA USA
Seattle, WA USA
Excellent advice!
dont augh  smiley-razz   what do you think?
int states[4];
pinMode(switchPins[a], INPUT);
pinMode(lightPins[a], OUTPUT);
pinMode (time_button, INPUT);
    if (button == HIGH) {
  digitalWrite(lightPin, HIGH);
  delay(900000UL);
  if (timeButton == HIGH) {
    delay(900000UL);
    digitalWrite(lightPin, LOW);
    toggleWithLongDelay(state[a], lightPins[a], timeButton == HIGH);
UK
Online Online
I think don't use b as as loop count, and a as an index
Seattle, WA USA
Seattle, WA USA
The loop function is missing. The code to read the switch states is missing. The toggle... function should not call the toggle... function; the loop() function should.
geting there?
#define time_button 7
int states[5];
for(byte f=0; f<5; f++)
pinMode(switchPins[f], INPUT);
pinMode(lightPins[f], OUTPUT);
void loop ()
    if (switchPins == HIGH) {
  delay(900000UL);
  if (time_Button == HIGH) {
    delay(900000UL);
    toggleWithLongDelay(state[f], lightPins[f], time_Button == HIGH);
UK
Online Online
You can't nest function declarations
Seattle, WA USA
Seattle, WA USA
geting there?
Using the verify button on the IDE is orders of magnitude faster than copying the code and pasting it into a reply, and waiting for us to tell you that that won't compile.
i'm a bit confused of how to write it within the loop
Ft. Worth, Texas
Are you using the compiler?
In Arduino IDE, it's under Sketch -> Verify/Compile
Or Apple+R on OSX. (Probably ctrl+R on windows)
KF5RVR
Seattle, WA USA
Seattle, WA USA
If you mean that you are confused about how to write the toggleWithLongDelay() function in loop(), the answer is that you don't. The toggleWithLongDelay() function goes either before or after loop(), and you call it from within loop().
hi thought i would post some pic's of the finished product:
Pages: 1 2 [3]   Go Up
