Topic: ISR(TIMER1_COMPA_vect) (Read 5734 times) previous topic - next topic
Manuel_Silva
I am learning C and have the following problem:
I want to use timer interrupt routine. The routine works, the LED switch ON and OFF. In side of the routine I want decrement a counter. The routine is below:
(I declare the count variable as "volatile uint16_t count=0;").
Code: [Select]
ISR(TIMER1_COMPA_vect)          // timer compare interrupt service routine
  digitalWrite(ledPin, digitalRead(ledPin) ^ 1);   // toggle LED pin
  count--;
   if (count=0)
    TCCR1B =0;
I want decrement a counter (count) and stop the timer when it reaches zero, but, the counter doesn't decrement.
Can you please help on solving this problem?
Thanks,
Manuel
nickgammon
Code: [Select]
if (count=0)
To compare you need to use ==, like this:
Code: [Select]
if (count == 0)
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
bubulindo
Code: [Select]
   if (count=0)
Ahhh, thanks for this. :)
I have some fun memories from a friend of mine that never managed to get this right. And he knew how to program, and yet never came to memorize the difference between "=" and "==". LOLOL
This... is a hobby.
Manuel_Silva
Thanks for your help. It was really a crazy question. It was lat in the night, so, I may was sleeping.
regards,
Manuel
