Topic: ArduCopter V1 Beta (Read 2029 times) previous topic - next topic
jordi
Nov 07, 2007, 06:27 am Last Edit: Nov 07, 2007, 06:46 am by jordi Reason: 1
http://[img]http://farm3.static.flickr.com/2405/1895501655_1fc0012b4d.jpg[/img]http://www.flickr.com/photos/18257187@N08/1895501655/
1: English is not my firts language, sorry if i made mistakes trying to describe this project.
I made an autopilot for my RC helicopter (Sabre, i bought it in Hobbie People USA) with acelerometers extracted from the NunChuck of nintendo Wii. Now i just a beta, i will change the Arduino Decimila for the mini version, you know, for weight reasons.
Arduino just control the Axis X and Y of the helicopter, but i able to read signals coming from my RC, an order to arduino to move my helicopter, easy and smoothly in that axis (X & Y), i only have to control the rotation and altitude, the rotation is not a big deal because the heli is stabilized by build-in "Gyros".  I recycled the joystick axis of NunChuck, to adjust the servos with out touching the code. To se more pictures enter here http://www.flickr.com/photos/18257187@N08/
The code:
Code: [Select]
#include <Wire.h>
#include <string.h>
#include <stdio.h>
uint8_t outbuf[6];            // array to store arduino output
int cnt = 0;
int ledPin = 13;
int voltPin = 2;
int apX = 0;
int apY = 0;
int minWii = 330;
int maxWii = 694;
int axisX = 0;    //Acelerometer axis X
int axisY = 0;    //Acelerometer axis Y
int axisZ = 0;    //Acelerometer axis Z
int adjustX = 127;       // adjust axis X
int adjustY = 127;       // adjust axis X
int contador = 0;     //Contador del ciclo FOR
////////////////////Read RC
int xPin = 7;          //Pin IN of servo Axis X
int yPin = 8;          //Pin IN of servo Axis Y
int timeX = 0;  //Show the readed control position
int timeY = 0;
long lastPulseX = 0;    // the time in milliseconds of the last pulse
long lastPulseY = 0;
long mstime = 0;     // reads the time in miliseconds
long hptime = 0;     // Reads the time in Microseconds
///////////////////Write Servos
int minPulse = 800;   // Minimum servo position
int maxPulse = 2200;  // Maximum servo position
int refreshTime = 20; // the time needed in between pulses
int servoXPin = 2;
int servoYPin = 4;
long lastPulseWriteX = 0;    // the time in milliseconds of the last pulse
long lastPulseWriteY = 0;    // the time in milliseconds of the last pulse
int pulseX = 0;        // Amount to pulse the servo X
int pulseY = 0;
extern volatile unsigned long timer0_overflow_count; // Sistema de conteo en microsegundos
unsigned long hpticks (void)
 return (timer0_overflow_count << 8) + TCNT0;
void setup ()
 pinMode(servoXPin, OUTPUT);  // Set servo pin as an output pin
 pinMode(servoYPin, OUTPUT);  // Set servo pin as an output pin
 pinMode(xPin, INPUT); //The R/C signal pin as an input pin
 pinMode(yPin, INPUT);
 pulseX = minPulse;           // Set the motor position value to the minimum
 pulseY = minPulse;           // Set the motor position value to the minimum
 beginSerial (38400);
 Serial.print ("Finished setup\n");
 Wire.begin ();            // join i2c bus with address 0x52
 nunchuck_init (); // send the initilization handshake
void loop ()
 Wire.requestFrom (0x52, 6);      // request data from nunchuck
 while (Wire.available ())
   outbuf[cnt] = nunchuk_decode_byte (Wire.receive ());      // receive byte as an integer
   digitalWrite (ledPin, HIGH);      // sets the LED on
   cnt++;
 // If we recieved the 6 bytes, then go print them
 if (cnt >= 5)
   print ();
   AutoPilot();
   updateServo();
   Serial.print ("\r\n");
 cnt = 0;
 send_zero (); // send the request for next bytes
 delay(5);
void AutoPilot()
   pulseX =((((axisX - minWii) * ((maxPulse-minPulse)/(maxWii-minWii))))+minPulse)-127;
   pulseY =((((axisY - minWii) * ((maxPulse-minPulse)/(maxWii-minWii))))+minPulse)-127;
   pulseX = pulseX + adjustX;
   pulseY = pulseY + adjustY;
   pulseY = maxPulse - (pulseY - minPulse);
     if(axisZ <= 754)//just a test
     if(axisX <= 500)
       pulseX = pulseX - 300;
     if(axisX >= 560)
       pulseX = pulseX + 300;
   Serial.print ("SrvX");
   Serial.print (pulseX);
   Serial.print ("\t");
   Serial.print ("SrvY");
   Serial.print (pulseY);
void RadioControl()
 if(millis() - lastPulseX >= 200) //Read Axis X every 5 milis
   while(!digitalRead(xPin) == HIGH) //Waits for signal coming from axis X
     continue;
   mstime = millis();
   hptime = hpticks()*4; //When the signal arrives, here we going to record the start time of reciving
   while(!digitalRead(xPin) == LOW){
     continue;
   mstime = millis();
   timeX = (hpticks()*4) - hptime;  //Here takes the diferences of  the Start and finish times, the result is the signal from RC.
   hptime = 0;
   Serial.print ("CtrX");
   Serial.print (timeX);
   lastPulseX = millis();
 ///////////////////////////The same, but now for axis Y
 if(millis() - lastPulseY >= 200)
   while(!digitalRead(yPin) == HIGH){
     continue;
   mstime = millis();
   while(!digitalRead(yPin) == LOW){
     continue;
   mstime = millis();
   timeY = (hpticks()*4) - hptime;
   Serial.print ("CtrY");
   Serial.print (timeY);
   hptime = 0;
   lastPulseY = millis();
//Continue
jordi
//code continue
Code: [Select]
void updateServo(){
if (millis() - lastPulseWriteX >= refreshTime) {
       digitalWrite(servoXPin, HIGH);   // Turn the motor on
       delayMicroseconds(pulseX);       // Length of the pulse sets the motor position
       digitalWrite(servoXPin, LOW);    // Turn the motor off
       lastPulseWriteX = millis();           // save the time of the last pulse
if (millis() - lastPulseWriteY >= refreshTime) {
       digitalWrite(servoYPin, HIGH);   // Turn the motor on
       delayMicroseconds(pulseY);       // Length of the pulse sets the motor position
       digitalWrite(servoYPin, LOW);    // Turn the motor off
       lastPulseWriteY = millis();           // save the time of the last pulse
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits.  That is why I
// multiply them by 2 * 2
void print ()
 int joy_x_axis = outbuf[0];
 int joy_y_axis = outbuf[1];
 int accel_x_axis = outbuf[2] * 2 * 2;
 int accel_y_axis = outbuf[3] * 2 * 2;
 int accel_z_axis = outbuf[4] * 2 * 2;
 int z_button = 0;
 int c_button = 0;
 // byte outbuf[5] contains bits for z and c buttons
 // it also contains the least significant bits for the accelerometer data
 // so we have to check each bit of byte outbuf[5]
 if ((outbuf[5] >> 0) & 1)
   z_button = 1;
 if ((outbuf[5] >> 1) & 1)
   c_button = 1;
 if ((outbuf[5] >> 2) & 1)
   accel_x_axis += 2;
 if ((outbuf[5] >> 3) & 1)
   accel_x_axis += 1;
 if ((outbuf[5] >> 4) & 1)
   accel_y_axis += 2;
 if ((outbuf[5] >> 5) & 1)
   accel_y_axis += 1;
 if ((outbuf[5] >> 6) & 1)
   accel_z_axis += 2;
 if ((outbuf[5] >> 7) & 1)
   accel_z_axis += 1;
 axisX = accel_x_axis;
 axisY = accel_y_axis;
 axisZ = accel_z_axis;
 adjustX = joy_x_axis;
 adjustY = joy_y_axis;
 Serial.print ("JoyX");
 Serial.print (joy_x_axis, DEC);
 Serial.print ("JoyY");
 Serial.print (joy_y_axis, DEC);
 Serial.print ("AclX");
 Serial.print (accel_x_axis, DEC);
 Serial.print ("AclY");
 Serial.print (accel_y_axis, DEC);
 Serial.print ("AclZ");
 Serial.print (accel_z_axis, DEC);
 Serial.print ("btnZ");
 Serial.print (z_button, DEC);
 Serial.print ("btnC");
 Serial.print (c_button, DEC);
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char
nunchuk_decode_byte (char x)
 x = (x ^ 0x17) + 0x17;
 return x;
void nunchuck_init ()
 Wire.beginTransmission (0x52);      // transmit to device 0x52
 Wire.send (0x40);            // sends memory address
 Wire.send (0x00);            // sends sent a zero.
 Wire.endTransmission ();      // stop transmitting
void send_zero ()
 Wire.send (0x00);            // sends one byte
//Remember i just a BETA, letter ill upload video,
trialex
Very impressive! I can imagine the first time you fired it up would have been scary!
MikMo
Thats a very impressive project.
You absolutely have to post a video of this thing flying :-)
Cheater
Now all you need is a GPS from SparkFun and a compass.
Then you'll be able to do waypointing.
Syvwlch
Careful with the compass, it will need to be tilt compensated which is not trivial.
jds
I am 'addicted' to r/c (airplanes) and this is one of the most impressive projects I have seen in while! Did you post this at http://www.rcgroups.com?
Cheater
Quote
Depends on how much maths you've done I suppose.
Given a compass bearing and accelerometer data I could probably make the compass accurate without having done it before.
I had (have?) a remote control plane. It liked to nose dive and the plastic propeller didnt like it too much.
It was a cheap one though. I'm looking in to getting a pricier helicopter.
jordi
#8
Nov 17, 2007, 08:35 am Last Edit: Nov 17, 2007, 08:37 am by jordi Reason: 1
Hello people, i already have the beta 2 of arducopter, but right know i dont have time to translate (weakness), but if you wish to see more pictures and know a little bit of spanish, enter here:
http://gizmobits.com/2007/11/16/arducopter-beta-2/
by the way is my personal technology blog..
anthony0
You're English is very good; don't worry too much about translations; a picture is worth a thousand words, and we're excited to see a video if you ever get the time to do so.  That's an excellent helicopter you put together.  It's cool that people are coming up with complex ideas and getting them to work. :D
Buy a breadboard; it's worth it!
jordi
#10
Nov 20, 2007, 11:23 am Last Edit: Nov 20, 2007, 11:34 am by jordi Reason: 1
Hola!
I have a video, to show that is real: http://www.youtube.com/watch?v=7xkJseQyhJA
Ok, i had a big problem, but i already solve it, the vibration of the main rotor, cause a lot of interference with the accelerometer, i almost leave this project for that. But i was googling around, and i found a group of student that try to make the same like me.. jejej here is the link: http://www.mne.psu.edu/me415/fall04/boeing4/
Well wathever, i used, i dont how to say it, in spanish are call "Ligas" links, is plastic bands. To put the accelerometer in the center and adsorb the vibrations. For my surprise i be able to reduce 90% to 95% of the vibration.
For pictures and translation of the original post (with google), enter here:
http://gizmobits.com/wp-content/uploads/2007/11/cimg0124.JPG
http://gizmobits.com/wp-content/uploads/2007/11/cimg0127.JPG
http://translate.google.com/translate?u=http%3A%2F%2Fgizmobits.com%2F2007%2F11%2F18%2Fmejoras-en-el-arducopter%2F&langpair=es%7Cen&hl=en&ie=UTF-8
jds
#11
Nov 20, 2007, 05:09 pm Last Edit: Nov 20, 2007, 05:10 pm by jds Reason: 1
Can you place your accelerometer on a piece of soft foam? You might be able to get rid of more vibration...
Edit: Oops, I wrote that after watching your images... never mind (probably).
jds
Hola Jordi,
You made it to Make Magazine: http://blog.makezine.com/archive/2008/01/arducopter_arduino_helico.html?CMP=OTC-0D6B48984890
Congratulations!
big93
