Loading...
Pages: 1 [2]   Go Down
Author Topic: How to wire up LM386 amp for audio?  (Read 4214 times)
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
Here is a great site for audio electronics fundamentals and projects. It's Hi-Fi orientated but has great articles on fundamentals and his projects are well explained and are a great learning experience even if you don't build any of his circuits. Take your time looking around as there are lots of different sections and topics covered and can take quite awhile to see it all.
http://sound.westhost.com/index.html
Lefty
Logged
CO, USA
Offline Offline
God Member
View Profile
Lefty
Quote
Not all have been built and verified, but with those that have not this is not an issue, since they cannot help but work.
Heh. Reminds me of Donald Knuth.
Also, bookmarked for educational purposes, and because a headphone amp is on my list.
« Last Edit: October 22, 2011, 11:36:38 pm by justjed » Logged
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
I think good results can be obtained by wiring the part per the Applicatin Hints on the datasheet as well.
Having a picture of the chip with no indication of what the pins are is not helpful.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
Your next step is to ensure the signal you feed into the amplifier is a good signal.
Amplifiers are a bit like software programmes   -   rubbish in = rubbish out.
There's no point in playing with filters until you establish that you are feeding a clean signal into the unit.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
Thanks for the replies guys! =)
however.. if I knew how to do the quick term suggestions you are giving.. I wouldnt need to be here on an help forum (looking for help/guidance)
@Crossroads-
I guess I dont understand your post?
in my diagram.. all pins 'are' labled.... can you not see them?  everything is labeled.. (except a missing 'to GND' lable)
**now if you are saying I should wire it up DIFFERENTLY.. please say so or point out how.. just implying so doesnt offer my much 'real direction to solve/fix anything.  but Im unclear as to what it is you are proposing?  (except post a schematic?)
@jackrae -
I understand what your saying.. but wouldnt have any clue on HOW to go about what it is you are suggesting?
So if trying to play with filters to fine tune the noise/sound is jumping the gun.. how do I go about doing as you suggest? (making sure its a good signal?) or if its not.. making it a 'better' signal!??
Thanks  =)
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
I think that all you can really do is minimise distortion, you should avoid "overdriving" (clipping.)  You may have a portable radio and with fresh batteries at low and medium volumes it's OK, but when you really turn it up it starts sounding crummy - some of that's distortion, over-amplification, and some of it is just exposing certain limitations of the amplifier.
This sort of electronic sound, derived from a noise generator or noise generation techniques, isn't instrument-quality.  It sounds pretty nifty at low volumes, but there's a threshold whereat all of the faults can be appreciated.
Anyway, the LM386 datasheet shows a X50 example.  It still uses the 10uF but with a 1200Ω resistor between it and pin1.  There is also a "bypass" capacitor that can be connected between pin7 and GND.  They don't give much guidance, text and example values from 0.1 - 10uF.
"When using the LM386 with higher gains (bypassing the 1.35 kΩ resistor between pins 1 and 8 ) it is necessary to bypass the unused input, preventing degradation of gain and possible instabilities. This is done with a 0.1 µF capacitor or a short to ground depending on the dc source resistance on the driven input."
Post Edit -- bonk inadvertent smiley
« Last Edit: October 23, 2011, 11:16:09 am by runaway_pancake » Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
CO, USA
Offline Offline
God Member
View Profile
He means functional labels, such as GND, SIGNAL, GAIN, etc.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
@justjed-
ahh..thanks.  I suppose that WOULD help people follow the diagram easier.  (I can make changes...np)
here is updated diagram...
showing a legend for PIN-OUT on the lm386 and the 10uF cap added for GAIN
@runaway_pancake-
some of it makes sense.. like over-driving.. makes the audio go 'crap' (clipping/distortion)
Im trying tp understand what it is I shoudl do from your comments..
1.) add a 1.2k resistor to the 10uF cap I added to the GAIN... yes?   (does it matter what side I put it on? +  or - side of the cap?)
2.) add a 0.1uF cap to pin 7 (bypass pin) to GND...
correct?
anyone care to help educate me about how to define or figure out anything about the signal BEFORE it goes to the amp/LM386?
was a comment about signal integrity BEFORE it goes there..  but I wouldnt have any clue on that.
a quick background on the sound INPUT (SND out from the PIC chip)..
I am using a PIC24FJ chip.. flashed with an API of some sorts to let noobs write generic code based on the API/instruction set.. (this 'code goes on .txt file on SD card..which is then loaded into the PIC chip upon powering it up)..
this is not mine.. I have no control over it..
however it has an EASY API to use..for doing simple things like PWM and playing audio..etc..  ( a very simple and generic platform)..
the PIC chip itself.. (somehow)  outputs Audio on its set pin(s)... this is what I am trying to use/tap so I can output to a speaker..etc..
anyways.. thanks you guys for the replies so far.. and understanding that not everyone has the skill sets you may have become accustomed to!  =)
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
I was thinking more of posting a schematic.  This is much easier to see what is happening electrically.
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
I don't think it matters, but they show it between pin1 and Cap+, Cap- going to pin8.
"Experiment for value", try various cap values, one lead to pin7 and the other to GND.  If it has a good effect then use it, if it makes things worse or has no effect then lose it.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
hi guys--
@crossroads-
I understand.. but schematics like that take some people time to understand or learn.  (especially symbols, and how wiring can be followed/traced)..etc
which is why I asked/posted for an image/diagram.. vs schematic.
I understand 'better get used to reading schematics if you want to be in this hobby'...(yadda yadda)..  (those kinda statements dont do much in HELPING one learn or be better) the OP can usually only give the resources knowledge he has. =)
for me thats a image/diagram of how I have things wired.
@runaway_pancake-
That I will try that, test different values and see what I 'see' (hear) =)
Anyone care to tackle the comment made previously about the signal out of/from the PIC chip? since it was mentioned that all this other stuff means nothing if that source signal is no good?
thanks!
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
Well, I did.  It's not that it's "no good", just that it is what it is.  If it's clipped/over-amplified that's a matter you can take steps to address, but beyond that, you cannot transform square waves and pulses into pure sine waves.
What is the sound quality compared to your other amp (better/same/worse)?  (If it's like the one I'm thinking it is, that's LM386-based, too.)
Maybe give that input capacitor (ac-coupling cap), the one between the source and the pot, a go.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
hmm.. good question..
I suppose the RadioShack amplified speaker isnt 'that great' either..  but only at low/mid volume at best.
I have no idea what that amp is based of. (LM386 or other)..
ok so what left for me to play with/eperiemnt with is:
2.) add a 0.1uF cap to pin 7 (bypass pin) to GND... (and play with values from there) (if I have that that value) smiley-cry
3.) add a 10uF 'ac-coupling capacitor' between the source and the pot..
I'll give those all a go.
thanks
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
