2nd star on the right
Everything I am is classified under the official secreats act!
« on: October 25, 2011, 02:07:16 pm » |
I have an Arduino Uno, a 16X4 lcd, a 3X4 numeric keypad. I need to build an alarm clock that can store different alarm times for each day of the week. I'd like to be able to set the time via the keypad and have the lcd show the time and date and control the brightness but I would also like to control some sort of radio or mp3 player.
Can this be done with and Arduino Uno.
Sorry for the noobish post but my knowledge is 10 years out of date!
Boston area, metrowest
Online
« Reply #1 on: October 25, 2011, 02:20:28 pm » |
Yes. Get yourself an RTC chip too, make it even easier. Install it on a protoshield with some transistors or relays to control the radio or MP3 buttons.
Central MN, USA
« Reply #2 on: October 25, 2011, 07:46:42 pm » |
Check out my alarm clock on my blog. liudr.wordpress.com search alarm clock. Source code is on the blog.
Oz
« Reply #3 on: April 20, 2012, 01:16:26 am » |
Liudr,
That is so close to what I want.
I went to your site but as I am new to this, I couldn't find the sketch for the project.
Central MN, USA
« Reply #4 on: April 20, 2012, 08:26:51 am » |
Liudr,
My site no longer host any code. Everything is on google code. Search phi_prompt user interface library in code.google.com and find the code in downloads. I'm typing on an iPad. It's too hard to copy paste you a link. Should have bought a real computer with the money.
Oz
« Reply #5 on: April 20, 2012, 04:21:03 pm » |
While I have you though, couple of questions:
1 - The display looks/seems/is different to the one I bought. I bought the main board - an Etherten - and a display as t was obvious I would need one. But mind is only a 2 line display. In your example it is a 4 line.
2 - As ther is now an RTC available for the Arduino, I want to get one - though just now I realise/think it doesn't have a battery, so what's the point? - I don't know how it would "fit" into what you built.
3 - (I can't count) Is there a "spare pin" which is an "alarm status output"? That is: A pin which goes high when the alarm is active? Actualy a couple of spare pins would be nice. And it begs another question:
4 - How long is the alarm active?
Oz
« Reply #6 on: April 20, 2012, 04:24:48 pm » |
Oh, P.S. This phi_shield....
Which I take it goes between the main board and the display.
I take it I buy it from you?
Oz
« Reply #7 on: April 20, 2012, 04:47:27 pm » |
Thanks, got the Sketch for the clock.
I am really going to make a fool of myself how.
I am reading the instructions at the top of the sketch and it tells me to download the libraries - fair enough - and put them in arduino\sketchbooks\libraries\.....
I'm confused.
Slight problem: When I downloaded the arduino program it unzipped into "arduino-1.0" which is in C:\program files The sketchs I make/get/what ever are in "My documents\arduino"
So where do these files go? In the program's directory or the My documents part?
I can try both in the mean time.
Oh, and should I re-name my "main" directory from arduino-1.0 to just arduino?
Central MN, USA
« Reply #8 on: April 20, 2012, 11:31:10 pm » |
1. Mine has 20X4 characters and your probably has 16X2. No problem. The program automatically fits on your display. All you need to do is to set the display size in two lines of code. 2. My RTC is on board my phi-2 shield, which has a battery backup so time is not lost even you power off arduino. 3. Yes, the buzzer pin is turned on with tone() when alarm turns on. You can add other stuff, say turn pin 9 to high and pin 10 to low if you want, in the alarm code in addition to turning on the buzzer. 4. It's active until you turn it off, so annoying, yes, that's the purpose
Central MN, USA
« Reply #9 on: April 20, 2012, 11:36:00 pm » |
Central MN, USA
« Reply #10 on: April 20, 2012, 11:40:58 pm » |
I'm confused.
The "Phi_2_project_alarm_clock_v5" folder goes to where you store your arduino sketches, for example (where your arduino 1.0 is)\sketchebookks\ so you will have a (where your arduino 1.0 is)\sketchebooks\Phi_2_project_alarm_clock_v5\ folder with the program files in it. The libraries go into (where your arduino 1.0 is)\sketchebooks\libraries\ since they are contributed libraries so you will have these folders: (where your arduino 1.0 is)\sketchebooks\libraries\phi_interfaces\ with phi_interfaces.h directly under this folder (where your arduino 1.0 is)\sketchebooks\libraries\phi_prompt\ with phi_prompt.h directly under this folder ... Just do make (where your arduino 1.0 is)\sketchebooks\libraries\phi_prompt\phi_prompt\, where you have two layers of folders both called phi_prompt.
Oz
« Reply #11 on: April 22, 2012, 04:33:19 pm » |
(We maybe should take this to another post or message eachother.)
Ok thanks.
There was no "sketch" folder made when I unzipped the arduino file, and nothing in the "my documents\arduino" folder either, so I am going to have to do some moving.
The libraries folder is simply in the arduino-1.0 folder not arduino-1.0\sketches.
Anyway, I'll work it out now I hope.
I bought the display - as it was kind of needed when I bought the arduino board for the alarm clock. So as your menu system allows 2 line displays, well, I shall live with that.
I'll look at the links you supplied and get to order the phi-2 shield, and RTC.
I am going to get the code printed out and the libraries so I can read, study and maybe learn what is going on.
This is important to me as my alarm clock is pretty well dead in the water and I need a working alarm clock. Mine is somewhat modified to do extra things which I am sure the arduino can/will do in the future once I get it working.
Oz
« Reply #12 on: April 22, 2012, 04:41:56 pm » |
Yikes!
Well, not really.
Looking at your link, the display withthe Phi-2 board is different.
My display which bought already has the buttons/switches on it. It is a "legitimate" board from freetronics.
I shall get a piccie of the display I have and post it.
In the mean time I may talk to the guys where I got it and see if something can be worked out.
The "buzzer" output is simply a buzzer, not a pulsed output to make the noise - right? So I could simply unplug the wire to the buzzer and put it else where to do other things.
Oz
« Reply #13 on: April 23, 2012, 02:25:31 am » |
Liudr, I went to your site and posted a couple of things there, and they now seem to be gone.  Looking at the Phi-2 instructions, I found a couple of "faults" - luckily minor ones. I don't think here is the place to specifically mention them, can you help me with a method of pointing them out? Couple of other questions - I shall hope to buy the shield from you soon, but need more things clarified. I notice the shield has buttons on it. I bought a LCD shield as I have mentioned and it too has buttons. Kinda defeats the purpose if there are two sets of buttons. I dug up an old LCD display I bought, it is a LCM-5044, or GEB-2294V-0 S. Suffice to say is it a BIG display. Could/would it work with the adrino and your shield? The GPS module would be nice and handy to use as a time sync. Every now and then I would/could poll it and get the time and then re-set the clock to the right time. I'll take it that this would be possible, but there is a problem with location. The clock would not be near a window or have a good sky view. So the GPS module would have to be remotely connected. Say 5 metres distance. Cat 5 cable and a small box? I would wire up another RJ45 socket and plug it in - but am looking for thoughts if this woud/could work. There is also now (I hear) cards to play MP3 sounds from a small SC card. Could one of these also be included to play a sample when the alarm goes off? I feel there won't be enough I/O lines to do all this, but I would like to get a feel for what the unit can do before I get my hopes up too high.
Central MN, USA
« Reply #14 on: April 23, 2012, 01:29:25 pm » |
The phi-2 shield includes an RTC
